Hi All.
My last test on 980X, using Cooler Master V8:D
http://img827.imageshack.us/img827/7650/1m980x.th.jpg
:up:
Hi All.
:up:
Can you post your bios settings that you used to get 4.7ghz stable. I can get 4.6ghz stable but am having issues with 4.7ghz. Thanks
Kein LLC2? Warum zur Hölle nicht? :confused: erm, sorry. click. English...
LLC2 is not a problem at all. LEVEL TWO means voltage dropping OFF.
It has been done for years on previous platforms...and I've been doing it on at least a dozen chips 24/7 up to 1 1/2 years. It is NOT a problem if you don't do hilarious stuff like running >1.4Vcore 24/7. Keep in mind, most boards don't even have an intermediate level 1.
Anything beyond 1.35V is likely to lead to overheating on air anyway.
Yo Amurtigress,
I donīt argue.
But it is a matter of fact that level 1 is safer than level two. Disabling the LLC sets the VDroop following Intel specs. Itīs better safe than sorry. I donīt know how much voltage :Damian: is going to set on his chip.
Are you ready for a quick hint?
How much VCore and Vtt should I use to get a BLCK 167MHz*24 stable?:shrug:
For 3750 MHz (163*23) my system needs 1.25 V (=real 1.216V)
Mem. should run at 2000 MHz then
Sure.
Advanced CPU Features:
CPU Clock Ratio ................................ [33]
Intel(R) Turbo Boost Tech ...................... [disabled]
CPU Cores Enabled .............................. [2]
CPU Multi Threading .............................[enabled]
CPU Enhanced Halt (C1E) ........................ [disabled]
C3/C6/C7 State Support ......................... [disabled]
CPU Thermal Monitor ............................ [disabled]
CPU EIST Function .............................. [disabled]
Virtualization Technology ...................... [enabled]
Bi-Directional PROCHOT ......................... [enabled]
Uncore & QPI Features:
QPI Link Speed ..............................[6600]
Uncore Frequency ............................[2500]
Isonchronous Frequency ......................[auto]
Standard Clock Control:
Base Clock (BCLK) Control .......................... [144]
BCLK Frequency (MHz) ................................[3300]
PCI Express Frequency (MHz) ........................ [100]
C.I.A.2........................................... .. [disabled]
Advanced Clock Control:
CPU Clock Drive ..............................[auto]
PCI Express Clock Drive ................... [auto]
CPU Clock Skew ............................. [auto]
IOH Clock Skew ............................. [auto]
Advanced DRAM Features:
Performance Enhance ...................... [standard]
Extreme Memory Profile (X.M.P) ........... [disabled]
System Memory Multiplier (SPD) ........... [8]
DRAM Timing Selectable (SPD) ............. [xpert]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ......................[8]
tRCD ..................................[8]
tRP ...................................[8]
tRAS ..................................[20]
CR.....................................[2]
B2B.....................................[auto]
Advanced Voltage Control:
CPU Intel Core i7 920 D0 Stepping
Load Line Calibration ................. [Level 2]
CPU Vcore ..............................[1.5250+]
QPI/VTT Voltage 1.150v .................[1.35]
CPU PLL 1.800v .........................[auto]
PCIE 1.500v ...........................[auto]
QPI PLL 1.100v ........................[1.16]
IOH Core 1.100v .......................[auto]
ICH I/O 1.500v ........................[auto]
ICH Core 1.1v .........................[auto]
DRAM
DRAM Voltage 1.500v .............. [1.70]
DRAM Termination 0.750v.......... [AUTO]
Ch-A Data VRef. 0.750v ...........[AUTO]
Ch-B Data VRef. 0.750v ...........[AUTO]
Ch-C Data VRef. 0.750v ...........[AUTO]
Ch-A Address VRef. 0.750v ........[AUTO]
Ch-B Address VRef. 0.750v ........[AUTO]
Ch-C Address VRef. 0.750v ........[AUTO]
hehe I know. What do you think about these memory?
http://www.newegg.com/Product/Produc...82E16820231374
regards:up:
@Solid Snake.. Thanks for the info it is much appreciated.
Hi Guys,
I have a i7 960 @3.2GHz and X58A-UD7/BIOS F6 and I really want up for @4.2GHz someone could help me with the exact values in the BIOS please?
Bios : 20.07.10
GA-EX58 - Previous Final/BetaBIOS
GA-EX58A-UD9 - F3 : Link
GA-EX58A-UD9 - F4e : Link
GA-EX58A-UD7 - F6 : Link
GA-EX58A-UD7 - F7u: Link
GA-EX58A-UD7 (rev2) - Fb2: Link
GA-EX58-Extreme - F12 : Link
GA-EX58-Extreme - F13i:Link
GA-EX58A-UD5 - F5 :Link
GA-EX58A-UD5 - F6j : Link
GA-EX58A-UD5 (rev2) - Fb9 : Link
GA-EX58-UD5 - F12 :Link
GA-EX58-UD5 - F13i: Link
GA-EX58-UD4 - F10 : Link
GA-EX58-UD4 - F11n : Link
GA-EX58-UD4P - F13 : Link
GA-EX58-UD4P - F14j : Link
GA-EX58A-UD3R - F5 : Link
GA-EX58A-UD3R - F6m : Link
GA-EX58A-UD3R (rev2) - Fb11 : Link
GA-EX58-UD3R - F11 : Link
GA-EX58-UD3R - F12h : Link
GA-EX58-UD3R (1.6/1.7) - Fl :Link
GA-EX58-UD3R (1.6/1.7) - Fj7 :Link
GA-EX58-UD3R-SLI - F9 : Link
GA-EX58-UD3R-SLI - F6m : Link
GA-EX58-DS4 - F11 : Link
GA-EX58-DS4 - F12h : Link
__________________
GA-EX58 - BIOSmod -
- Intel Raid/Ahci version : 9.6.0.1014 - Realtek Lan Controller Series v2.35
GA-EX58A-UD9 - bios f3 : Link
GA-EX58A-UD7 - bios f7u : Link
GA-EX58-Extreme - bios f13c : Link
GA-EX58-UD5 - bios f13h : Link
GA-EX58A-UD5 - bios f6i : Link
GA-EX58A-UD3R - bios f6j : Link
GA-EX58-UD4P - bios f14i : Link
GA-EX58-UD4 - bios f11g : Link
GA-EX58-DS4 - bios f12g : Link
GA-EX58-UD3R - bios f12g : Link
GA-EX58-UD3R (1.6/1.7) - bios Fj3 : Link
Thanks Andrea deluxe for the BIOS update :up:
There are a lot of templates with bios settings posted if you read back through this thread. All chips require different settings so you will hve to play around with yours and see what works. Noone can give you the exact settings for your chip. You dont have to find a template with an i7 960, you can use 920 930 or other bloomfield, you have a higher multi to work with but the other settings will work the same.
I'll give it a shot with F7u. F7t, just as F7r and Co. didn't get my D0 920 stable-Very contrary to F6.
Did run run any testing yet to see how the F7u works?
I am still thinking about updating to the latest BIOS:shrug:
Yo mate!
You are right- sometimes I do like playing with my system. :D
But believe it or not I had some issues with my audio since I updated to BIOS F7r. I blamed the creative driver for it at the first time. Now every issue is gone - since I have got the F7u running.:)
Fritz: What bug exactly?
I am running F7u now, and I got my chip stable at 4 GHz. Yet with more core voltage. 1.3125V as opposed to 1.2875V on F6.
Looks pretty clearly like an effect of the changed LLC in F7...
Overall the F7 BIOSses have a tendency to just hang when the board is supposed to start initializing the extra controllers, and the POST as such is faster in F6.
Not to mention the odd disabling of the USB power for mice and keyboards every two seconds when updating the current settings screen
The sound didnīt come up synchronously with the video.
I am happy that the problems are gone now:yepp:
So bios f7u is working nice?
This is the longest beta bioses I have ever seen before the final F7 come out.
Does anyone have settings for 5.0ghz with a 980X and do you think this can be achieved on water?
right now I have my 980x on 2 rads (360.2/240.2) plus 2 res. I had to take my gpus off blocks having some issues with my 5970. my idle at 4.4ghz are really good right now. I was thinking of just trying 5.0ghz to see if I could get a boot up and run a few benchmarks. What do you think would be my best option would be to achieve these goals.
