This is actually a Kaze Server, not the Kaze Master, but the look of the two is similar, afaik, plus I have some other mods going on in the front of my case.
I have been meaning to put this all in a worklog, but haven't gotten around to it, so thought I would just put this down here & now, hope that's an OK way to show off my mods & get feedback.
So far, along with doing the bottom hole/PSU flip, and holes in the Mobo tray for cable management, and flipping my HDDs, wiring the Sata cable using the inline connectors (what a cable crunch saver *that* is!!) I have also...
- removed all of the nine stock grill covers, and replaced six of them with a custom grill/bezel I made from a sheet of mesh panel from CrazyPC for $6.95, painted with ACRyan UV Green from Performance PCs
- installed the Kaze Server
- and a Mountain Mods Acrylic UV Green 5.25 bay cover to make it "pop".
- Obviously I switched out the fans, too, opting instead for UV Green/Orange (and vice versa) ACRyan Blackfire4 fans -- the airflow is a bit better at high speed, and I like the look.
- Since the entire fan looks cool, not just the round part, I also removed the black plastic fan mounts
- instead I have mounted the fans directly on the mesh front bezel, using UV Green Silicone fan mounts, which work nicely -- the only drawback being that it is a bit awkward when removing the bezel mesh piece to clean the filters, but not terribly so, and for the look, I am willing to have a bit of hassle anyway.
- That move also allowed me to install fan filters behind the front fans. I am using the DEMCiflex Fan Filters, which are magnetic, and so they stick to the front of the HDD cages perfectly and trap everything. I'd say that these filters effect on airflow, if any, is minimal.
I haven't decided whether I like the green bay cover with or without some of the mesh behind it, here are pix both ways, any thoughts on that? Currently it is out, and I am leaning towards putting it back inside, as I think it makes the front look more "together".
http://img190.imageshack.us/img190/9...shornomesh.jpg
By
cyclometric at 2009-08-24
I was working on making a mesh fan grill/guard for my side fan (also an ACRyan Blackfire4), since I have removed the stock metal mesh for more of an inside view (pic below).
http://img188.imageshack.us/img188/8...sidelatest.jpg
By
But now what I'd like to do instead is make one large window, removing both of the stock clear acrylic pieces, and replace them with a single rectangular UV Green acrylic piece. I would like to get this with a fan hole cut to where I know it fits for my setup (about .75" down and towards the back) -- but, and I read on a website based in the Phillipines or Malaysia, that this can be done so that a laser cut fan grill is cut directly into the window -- which would be so awesome! Plus, then I could get screw holes for the fan drilled directly into the window as well, and I would use more of the silicone fan mounts to attach the fan.
Has anyone heard of a shop somewhere that would laser cut such a piece for me, if I provide the specifications (and possibly the acrylic as well...)?? I have been searching without any luck and am considering asking that website in Asia to do this for me. I just think a single piece, with an awesome fan grill cut directly into the window, would set off the case beautifully.
I still have quite a bit of cable management to do . . . I have done some but wanted to wait til my UV Cathode lights came in, which they did last week so now I have no excuses!
