Rol-co,
Great to see my cpu gets a higher fsb in a other board.. so it aint the cpu that is holding down. (there is a prom waiting on youre desk to get used :p:)
Rol-co,
@ gamer,
use the large system cache for better 32m times ;)
I was informed - by PM - that there was another mobo went down by hicookie's Vchip (Northbridge) Mod......This mobo was down before mine......The guy propably thought it was his mistake.......:(
hicookie you should be ashamed of posting things like that in a VERY "readable" and crowdie forum without even testing it by yourself......:nono:
Originally Posted by hipro5
Thanks hipro, this solved my coldboot problems completly. ;)
Ready to rumble...:D
http://oc-x.de/PICS/AOpenstuff.jpg
Hope to get system running soon!
Originally Posted by kiwi
First i was thinking that too, but 2 cpu's here and so different, when i come too 244 fsb with mine i get the "not exact in round" @ step 10-17 or so,
with the cpu of waus-mod i get a instant lock up @239,5-240, nothing about error message or something else.
so when i can get 244 fsb with the cpu of mine , why can't it be cpu then? the board is not the problem i think.
Maybe it is possible too gain higher fsb on another board, but our japanese friend's here use the same board and gain a massive 280+ fsb.
@waus-mod
Sorry too tell you but i'm thinking it's cpu related :stick: , only thing is that becouse of the ihs on it it was a 10 degrees hotter as the cpu i'm using without.
so maybe that was not a good id too do before the ln2 run.
well w/o ihs i also had a 236.5 wall.... hmm can you hook up the prom?
I strongly believe that the problem with the fsb is a CPU > Northbidge > PLL generator chip related........IF AOpen whould be so kind to provide us a FULLY UNLOCKED bios with ALL features(deviders-multies-etc.), I think that we could solve a LOT of our problems......;) :)
Originally Posted by central
You're welcome.......:)
Yes, agree with you, but any BIOSmodder can do this :confused:Quote:
My T2400ES have a wall at 237Mhz it's too bad :(
Biosmodders aren't here anymore coz........there aren't any proggies out there to support newest bios files.......If we had a NEW Modbin proggie, I think that we whould be OK.......;)Quote:
:confused: a bios modder can't just add options to the bios, they can only lock/unlock options that are already coded into the bios
I can ask my contact for bios.. hope they will do it like you said hipro.
PM tony for that?Quote:
100% agree with you.Quote:
Originally Posted by Rol-Co
I freeze at double prime when :
low multi x 229MHz cpu@22°C full
low multi x 225MHz cpu@44°C full
low multi x 220MHz cpu@62°C full
I'm quite sute that 80-100% of the problem is related to cpu. Maybe we can improve it by raising the voltage of the fsb.Quote:
yep......i know, but under ln2 you gaint 4 mhz fsb more if i remember ok.Quote:
Originally Posted by Waus-mod
so maybe its cooler here @ air so i got the 4 mhz too......
i try the prometeia , but i think its not helping on you're cpu.
results later this weekend,.......bit busy atm
Ummm...I don't have any problem with booting into windows. I have a problem RUNNING the cpu IN windows...As evap temps get colder, the cpu becomes more FSB limited....Quote:
Originally Posted by albertwesker
my new mem arrived today :)
http://people.freenet.de/chris070719.../SuperPi-2.jpg
NICE cpu! Is that on air?
cpu is watercooled ;)
Okay, nice anyway :)
Has anybody tried to "burn-in" a Core Duo to see if it enables the cpu to run at higher FSB? I think it's kind of interesting because everybody hits a FSB wall..
i need more vcore :D
cpu can boot with 262FSB (3.4Ghz), but pi stable is only 258FSB :(
its still a sick chip.. it screams for ln2 / cascade!
Can you tell us FSB's limit related to cpu's temperature ?Quote:
Originally Posted by s7e9h3n
Looking good Chri$ch :slobber: - keep pushing and don't leave out any details.:)
