I added the super pi versions to the website for you alexgontijo. There are 3 version there, default, milisecond version and sse3 version. Have fun :)
superpi
superpi
My crapy cpu dose 2500mhz whit 1.53v and nothing more. Dumping in more volt dosent help.
well, got some Corsair 4400c25
guess what i can do with this ram? boot up at 250x10 1:1 1.4vcore 2.7vdimm 2.5-3-3-8 timings.
so that must mean my OCZ ram was bad.
so far this ram is working great!
I wait your stats with OCZ alexgontijo ! beacause I have Corsair 3200XL too and I can't run it over 260mhz rock stable 2.5-4-3-6 (nfm bios tweaks) ...
Goodbye.
Thanks a lot!!Quote:
Originally Posted by sideeffect
I shall have the OCZ with me in the next days, I'll post the results for sure!
Today I tested my CPU at 300x9 and the Corsair at 245 MHz 2.5-3-3-6. It's doing fine, 7K in Sandra, a 5% more than running at 225 MHz 2-3-3-6. I recommend it!!
AleX
Who was say official bios would be in end of June?? We are in July, and I don“t see any bios :slapass:
well there is now a 1.97 beta bios
1.97 beta
so many new bios which is good for UTT 2-2-2-5 at 250fsb
thx
What does the new 1.97 bios have that the others didnt?
i want to know too... anyone tested it out...
damn.... my RMA replacement raptor came to me DOA !!! gossshhh.. another few days on ubuntu livecd..... im starting to miss my OCing life... *sobbb
I haven't noticed anything except some ram timing changes from 1.96......nothing noticeable :shrug:Quote:
Originally Posted by 4rory
Dam that must suck, Hope the next ones fine, Just wanted to ask if anymore modded bioses are coming out, maybe the one with the 5.5ns hack that you turn on with logo setting in bios? I kinda need this since its all i need to be stable :D
hey guys i have som basic mushkin ram. i bought some back in nov of last year, and then i bought some last week. they want to run at diff timings....2.5-3-3-7 (old stick) and the other wants to run 3-4-4-8 (new stick) by SPD. the trip is that if i set the timings to 3-4-4-8 only the new rams works. the old ram wont run at the slower timings. but if i set the timings to 2.5-3-3-7 then they both work. this makes the only condition where the old stick will work is 2.5-3-3-7 or auto. new stick seems to work at those setting or by its spd.
so anyway if i set timings to auto (or i set them to the 2.5-3-3-7) no matter what combination i use both sticks at i get ddr333/166mhz ram speed. if i use each stick individually its fine. doesnt matter if i use dual channel or single channel, if they are both in there its ddr333
any suggestions?
i hope the new BIOS makes it in time for the 3800+ X2 :)
have any new modded bios by Murdok VID + 18% in bios and it is work??
thanks
Originally Posted by floodo1
Try to set new vdimm values, try like 2.6v, 2.65v, 2.7v and 2.75v. Use the software: Memtestx86 to verify if the memory is error-free. Download it, make a boot disk and run it like 4 loops. If it's error-free ok, if you got errors, try the next voltage option.
And set the 2.5-3-3-7 manually, don't use SPD. If you got no boot, remember to clear the CMOS - no panic. :)
If you get only errors, I suggest take a new pair of memory, like the dual-channel ready ones.
Let us know,
AleX
Try v1.98 official BIOS people, official at least on korean msi :p: . Link in my sig
EDIT: Modded 19b8 BIOS. Need someone to test it with bios savior or extra chip. Don't risk it!
A few thing about RAM. Most "manufacturers" do not make the chips themselves. Rather, the purchase the chips and PCB on the open market, test them to certain timings and speed, and sell them as their own. Any particular line of RAM could have different types of chips in them depending what was available on the market at the time. Sounds line you may have RAM that was produced from Winbond dies, the older set most likely being BH and the newer most likely CH. BH is well known for not booting into CAS 3 but will do 2.5 or 2.0 with proper voltage. Get that vDIMM up into the 3.2 to 3.3 range and you may find that your RAM can do 2-2-2-5 at fairly high speeds (~250MHz). I know the MSI board will not do that voltage. A vDIMM hack or OCZ DDR booster would correct that issue for you.Quote:
As far as having four double-sided DIMMs populating your motherboard's RAM slots...this will always cause your BIOS to revert to DDR333 speeds. Search these boards for much of this knowledge being repeated over and over ad nauseum. OK, I'm done here.
Hoping for that new BIOS :shrug:
Ok mate im gonna test it for you now.Quote:
Originally Posted by need.for.mhz
I downloaded the official bios from the korea site too... http://www.msi-korea.co.kr/program/support/support_dld_detail.php?part=1&serials=66&uid=K8N%2 0Neo2%20%ED%94%8C%EB%9E%98%ED%8B%B0%EB%84%98&name= %EC%86%8C%EC%BC%93%20939%20(AMD%20K8)&chip_id=51Quote:
but you modded it?
What did you mod anyway? :D
Changelog Rev.1 for 1.98 modded bios:Quote:
Originally Posted by Garrett
- Read Write Queue Bypass = 16x
- Bypass Max = 7x
- Idle Cycle Limit = 256 clks
- Max Async Latency = 8ns
- Write Recovery Time (twr) to 3clks
- All hidden options are now available
They are some memory tweaks that help with stability when OCing. Thanks for the latest bios NFM, i'll try it out once sideeffect has tested it. :)
Sorry im taking so long the bios does work the timings do set but im having the cant enter bios issue still. Its nothing to do with the NFM bios its a flaw in the 1.9's that effects some people.
CD1986 is quickly modding a no temperature version for me so i will be able to enter bios setup then. But the bios flashed fine and the modded timings are ok.
This bios shows the trc and trfc values so you can modify them at your own will, right?
Like this I mean:
http://home.megapass.co.kr/~rhgkswhd/bios1.jpg
yes
Works well NFM, all timings read correctly in A64 Tweaker! Any chance you might be able to enable 183 divider? Thanks :)
