Owi, did you clear the CMOS with the power unplugged after flashing?
This is probably the most important "Clear CMOS right after flash" BIOS.
Sin's CMOS is messed up because he has level 1, standard and level 2 still there...cuz he didn't clear the CMOS.
And the old LLC2 should be either #7 or #8 now, at least on UD5 and on the real_7's UD7. The real_7's UD7 software and DMM readings match my UD5 software reading.
The old LLC1 should be #4 (
Your board should not be dropping the vcore at load, it should be raising it.
Try clear CMOS, with power supply unplugged, then set LLC8 1.50v set in BIOS.
