New case. ^^
http://i4.photobucket.com/albums/y12...D/S6302811.jpg
New cable management of my lian li ! (Pictures take with n86 8mp...)
http://img4.hostingpics.net/pics/52056903032011197.jpg
Before>http://img4.hostingpics.net/pics/310142P3010250.jpg>After>http://img4.hostingpics.net/pics/30667203032011165.jpg>
http://img4.hostingpics.net/pics/19067803032011192.jpg
My blog...> www.cod-4vsgta-4.skyrock.com
I have assembled a PC for my Brother>
RIG spec:
i5 760@4.23ghz > zalman cnps10x extreme
3x1go corsair dominator+1go g-skill (rad cover memory slot...) @1688
Asus sabetooth 55i
sapphire hd4890 o/c(901mhz)
thermaltake 775watt
nzxt phamtom
seagate 1.5to(all)
http://img4.hostingpics.net/pics/650858P2280217.jpg
http://img4.hostingpics.net/pics/817235P2280218.jpg
http://img4.hostingpics.net/pics/35170506032011246.jpg
i go to take pitcure of insinde of the case...
so i have a oveclok picture xD
http://img4.hostingpics.net/pics/19232306032011250.jpg
Here's my rig until my GTX 580's, high-flow brackets and backplates show up on Tuesday...
http://img256.imageshack.us/img256/9...3014custom.jpg
http://img337.imageshack.us/img337/7...3020custom.jpg
http://img39.imageshack.us/img39/634...043mediumr.jpg
Got tired of not being able to find a desk I liked, so I built my own monster. 1" MDF construction, laminated, cable management, filtered audio power, Full HT setup with Polk Monitor's, and room for 3 LCD's for my eyefinity setup.
http://img607.imageshack.us/img607/939/p2200689.jpg
This is the best shot I got, before the edges were finished with a marker and some filling. I learned how much of a pain laminate was. The color is Basalt Slate, and it's from home depot.
http://img39.imageshack.us/img39/9152/pb250606.jpg
Thanx!!! :up:
I'll check if i can find it around...
The only thing I dislike about that desk, CJ145, is how the speakers are setup. I'd much prefer an exaggerated sound-stage (having FL/FR wider than normal) than that.
I recently did a little upgrade... I bought a MSI HD6870 Twin Frozr II.
I finaly succeded to resolve the pics problem, thanks to a friend :)
http://img200.imageshack.us/img200/1659/mg7281.jpg
http://img145.imageshack.us/img145/5770/mg7274.jpg
http://img339.imageshack.us/img339/8720/mg7267z.jpg
http://img856.imageshack.us/img856/250/mg7269a.jpg
http://img88.imageshack.us/img88/1012/mg7268a.jpg
http://img812.imageshack.us/img812/8369/mg7270f.jpg
http://img841.imageshack.us/img841/5334/mg7267a.jpg
My next build will most likely be integrated into a room, and I plan on making it sound as good as possible. This was more of a, okay, it won't fit anywhere else. In proper sitting position your ears are actually the same distance from each speaker and monitor (including center) and the left/right doesn't sound too close or too far apart. I might move them about 5-6" out if I could. It certainly doesn't help fill the room with them that close and at that angle, but it works perfectly for the 1 person sitting at the desk. I can easily pick up gunfire directions with this setup, where my old Klipsch 4.1 computer system I had trouble. I wish there was a way to mount them inside the monitors though... maybe projectors and mesh screens for my next setup.
I love seeing all the other eyefinity setups here, good to know there are so many. Hopefully all new games at least make an effort to support multi monitor gaming. The Crysis 2 demo was a massive disappointment to me when I saw the UI stretched across all 3 screens.
I would have a problem listening to speakers from a 30+° angle. The best way to do it would be to use Portrait monitors with Eyefinity. That'd give you 27:16 or 30:16 aspect ratios instead of 48:9 or 48:10. The latter options are far too wide while the former seem to lend a hand to even better accuracy. Bigger enemies and all.
Nice job with the custom desk!
Corsair 800D Build. Finally got around to taking some shots.
https://lh5.googleusercontent.com/_W...0/IMG_3645.JPG
https://lh3.googleusercontent.com/_W...0/IMG_3650.JPG
https://lh5.googleusercontent.com/_W...0/IMG_3653.JPG
https://lh6.googleusercontent.com/_W...0/IMG_3659.JPG
Just upgraded to an i7 finally. Some shots of my workstation.
https://lh4.googleusercontent.com/_q...0/P1000135.JPG
https://lh5.googleusercontent.com/_q...0/P1000149.JPG
https://lh6.googleusercontent.com/_q...0/P1000159.JPG
Updated shot of my rig, just got the GTX 580's w/ highflow brackets and backplates:
http://img812.imageshack.us/img812/3...3145medium.jpg
http://img146.imageshack.us/img146/7...3148medium.jpg
http://www.pctunerup.com/up/results/...1_IMG_3452.jpg
http://www.pctunerup.com/up/results/...4_IMG_3453.jpg
http://www.pctunerup.com/up/results/...6_IMG_3463.jpg
http://www.pctunerup.com/up/results/...2_IMG_3471.jpg
http://www.pctunerup.com/up/results/...8_IMG_3484.jpg
http://www.pctunerup.com/up/results/...7_IMG_3491.jpg
http://www.pctunerup.com/up/results/...4_IMG_3494.jpg
Poor Xfi! :(
