What case is that?
I also see a lot of people using Dell monitors. Are they good/cheap or something?
Yeah, Dell makes some pretty good LCDs, and there not too expensive.
That case is some type of silverstone, I believe. I love Silverstone/Lain-Li cases, but damn they are expensive :(
Got a P182. My Akasa was much wider, PSU is a total b*tch to install (whoever got lazy to make a removable PSU bay for the case needs to be *****) because of that useless FAN which i eventually had to remove, CPU temps got up by 5C idle/load, GFX up 10C idle/load :mad:, that's with the stock exhaust fans at their max rpm. I installed my trusty Scythe behind the top hdd rack also but it's not really handling it properly. I seriously need a side fan for the gfx/mobo, that'll make all the difference IMO.
I like the wire management and the elegant styling though, that's why i got it :)
http://ocidb.com/albums/userpics/101...l_IMG_2556.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2558.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2559.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2560.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2564.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2566.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2570.jpg
Are there any side panels with windows for the P182?
Lian Li PC-A71B
Whats in it....
Quad 3GHZ, TRUE, 4GB RAM, 2x2900XT, XFi Platinum, 7 SATA HDDs, 2xDVDRW, Zalman Fan cntrl, 850W Toughpower (it isnt enough)
http://img299.imageshack.us/img299/3...pc01di6.th.jpg
http://img180.imageshack.us/img180/4...pc03kr4.th.jpg
nice case!
Here's Mine
http://i20.photobucket.com/albums/b2...temPisyong.jpg
http://i20.photobucket.com/albums/b2...sidepocket.jpg
http://i20.photobucket.com/albums/b2...idepocket2.jpg
http://i20.photobucket.com/albums/b2...manMFC2Van.jpg
http://i20.photobucket.com/albums/b2.../quadcool1.jpg
http://i20.photobucket.com/albums/b2...AST/front1.jpg
http://i20.photobucket.com/albums/b2...AST/front2.jpg
http://i20.photobucket.com/albums/b2...AST/front3.jpg
@Pisyong: How'd you get all your hard drives inside?
@emoners
1 raptor x at the Top Panel dedicated for Raptor X for Stacker other raptor x at the hdd cage, 3x500 also in the hdd case and other 500gb ext. enclosure.
anything else?
thanks paps, thats the most amusing part of my rig (for me) hehe
kita ko icemat mo ah. fogi! hehe
My New Build...
http://www.mediamax.com/malkiewicz/Hosted/CIMG0420.jpg
Where is your radiator?
I have the 900 case as well, and am looking for ideas. I saw another thread in here with a great cable management plan (demel). I was contemplating internal radiator ideas. Can I remove the two front lower drive cages and fit a 2x120 radiator in there? Can I make some brackets and fit a 1x120 radiator hanging from the top 200mm fan? Does anyone make a radiator that would go with the top 200mm fan? Just trying to think outside-the-box (not literally in this case). This place seems to have the most creative case modders on the net.
My G70 build, loved working with this case. Used 2 loops, my overclocked ultra and high ambients were hindering my cpu OC. It was a pain putting in the Lian Li hard drive bay in front near top with PA 120.3, had to dremel a three drive holder into a two. And finally got wires hidden via holes in mb tray.
i like that alot Rge
I hope this helps... And yes you can keep everything inside the case...
I was able to run all the wires behind the MB and Drive Bays…
http://img176.imageshack.us/img176/9...449copyqe9.jpg
http://img297.imageshack.us/img297/3...opycopycg6.jpg
Happy New YEAR!!!
First Post of 2008!
http://i20.photobucket.com/albums/b2...SigQX68502.jpg
08? we are in 07 bro:D:D:D
