What is the best temperature monitoring software for this board?
I just setup a new system around this motherboard, and found that Speedfan, TAT, and Core Temp don't work at all. I did download the new Smart Guardian software from DFI, but I don't know if I can "trust" it, and also don't like the fact it does not show each cores temp.
Ideally, I want to get Speedfan or Core Temp working. Does anyone know how to do this? I know when I installed Speedfan 4.33, it actually caused my system to reboot, and I was not happy about that!
This board is working out quite well
I have some initial results with this board, and am pretty impressed. I have just done basic configuration in BIOS, yet my Q6600 B3 processor seems 100% stable at 2972 MHz/330 FSB with temperatures in Speedfan 4.32 being almost 15C (50 C 50 C 48 C 49 C) lower than the same setup on my Asus P5W DH motherboard as reported in Speedfan 4.33.
Just to verify, the temperature reported in Speed fan 4.32 and 4.33 are both accurate? As a cross check, Smart Guardian shows these temps under load (Prime 95 on all 4 cores):
CPU = 54 C
PWM = 53 C
Chipset = 54 C
Once I get verification that these are accurate temperatures, I will turn up the speeds a bit:D
