wow, nice result phil:clap:
That's roughly 100 mhz better than my 154 (I guess that sotck vcore means 1.372 in cpuz).
Strange that you can run pi that high, it must scale very well with temps.
I will try my 154 on teh same vcore and see what it can do someday, just to see how much worse it is:D
See my sig, I finally broke 3.2GHz on stock air cooling and 22c ambient :D
thanks guys ;)
the opt did nearly 3.3 ghz @ stock voltage under air cooler and the temps weren´t so high. dry ice will be the key i think.
yesterday i could run superpi with 3.83 ghz and 1.58 volts so i think with better temps it could be around 3.9 ghz.
1.7v + better cooling => superpi @ 4ghz!!!... 21days to go
Awesome OC. I would have to agree that is the best AMD 64 I've ever seen.
Hey Knut, I know you're busy so please don't see this as me rushing you, but you've got PM :)
ok 3.9ghz 32m stable.. would also be nice :D
I tried the last hours some prime with default vcore. this opteron will be stable between 3.6 and 3.65 ghz :D that is awesome !!!
with more volts i could go more than 3.85 ghz but the temps aren´t good so after some minutes the pc freezed.
Knut, no problem, I'm just excited :D
stunned_guy, that's not a CPU... It's a deity!
I know, I know :D
Today I tested with prime and default vcore: 3678 mhz @ 1.376 v @ sli-d.
I dont want to test more that will be at the session.
hehe that cpu is really insane...
I feel the smell of the oc session :D
Thanks guys ;) I hope this will be the ultimate cpu for me in my life under ln2.
I want that CPU when you're done with it :D
By the way, stunned_guy and Knut, could you please share your black/white lists with me? :)
Die or fly thats it ! :D If these cpu will be the golden one I won´t sell it.
If it doesn't make the cut and survives I want it!
That says volumes about QC at AMD
http://images24.fotosik.pl/188/1016e96b8e12f128.jpg good for ac :P ? Cpuz vcore is real.
I mean your list of good and bad steppings.
phil: http://www.nethands.de/pys/show.php4?id=38051
me: http://bastel-gianni.ch/overclocking-cpu.htm
btw: anyone knows another forum for here: http://test.ripping.org/database.php...umsort=country => if yes, feel free to add. ;)
@ gianni
My list is not up to date there are more than 10 cpus which aren´t in this list...
Yesterday I tested one 3500+ Manchester with 0632 APMW....but it sucks horrible :( Only 3080 Mhz with single stage and 1.7 volts under prime :(
The stepping sounds good but the rest was s.h.i.t. But the cold bug was great: 353 mhz @ -36c :D
