^Stock volts?
^Stock volts?
@nugzo How long did you dual prime for- did you use small FTT?Quote:
Originally Posted by Repoman
I broke down and ordered another 165, even though I burned in my current one to do 2754 @ 1.52.
Take the IHS off and u can reach 2.9ghz with a little more volts and with consistent burning.Quote:
Originally Posted by foodfightr
Hi guys
Hope you can help I am looking at getting a duel core 939 AMD Opteron but want to no which is the best for overclocking and what will achieves the most MHz I have heard that the 165 is best but thought that if I went for the 175 it would achieve more MHz as it has a higher clock speed to start with and a higher multiplier.
Anyway would most appreciate all your comments on this?
Cabinet Thermaltake Armor
MB: ASUS A8N32 -SLI
BIOS:1009
CPU:FX55
RAM: 2X 1G Ballistix DDR500
Boot: 2x Hitachi Deskstar T7K250 RAID0
Storage: 2x Maxtor 10 SATA
Graphics: 2X GAINWARD GeForce 6800 GT SLI
PSU: OCZ 600w Powerstream
Cooling: WATERCHILL/DangerDen
OS: Windows XP Pro SP2
Don't waiste your money unless you need the higher multiplier. I haven't seen a 165 yet that will not hit 175 speeds on default voltage. So the yields on these chips must be very good and it all comes down to luck of the draw. The 175 hasn't shown any better results than the 165 but there are some exceptional chips in both ranges.:fact:Quote:
Originally Posted by overvolt
http://www.xtremesystems.org/forums/...ad.php?t=86531Quote:
Other forums have their own database too
1.4v. I ruined a x2 4200 trying to take the IHS off. Whats the best way? And once its off, how do i make the HSF fit properly?Quote:
Sure sounds easy.:DQuote:
Originally Posted by situman
Got my 170 CCBWE 0550 UPMW today...... it's the 434 flavor..... ummmmmm!!
Initial results look promising. Fired right up at 2.6ghz.... went to 2.7Ghz.... still a go.... tried 2.8Ghz on stock voltage and finally core 1 failed prime. I backed it down to 2.75Ghz and just bumped the voltage to 1.45V. Dual prime is running for about an hour now @ 42C. OCCT passed so I am guessing prime will pass- at least thats my experience.
I could probably get this to 2,8Ghz with 1.5v or so, but 2.75Ghz at 1.45 will be just fine with me on my lowly air cooled rig.
That's about what mine does... It takes some pretty good voltage past 2.8 to get it to go higher but it definately goes like a raped ape w/o the IHS and some voltage :)Quote:
Originally Posted by cdelong
Sorry, I'd just got Opty 170 anh got nice result :p:Quote:
Originally Posted by iMAX
CPU : Opteron 170 (stepping CCB1E 0550VPMW, batch 334)
Cooling : DangerDen TDX water block
Mobo : DFI nf4-D mod SLI and SATA2 (bios 11/14)
Ram : 2*256MB Gskill TCCD 431
Overclock : 3G@300*10, vcore 1,5V (1,52V in bios)
http://i9.photobucket.com/albums/a10...%20170/300.jpg
Damn nice chip mate!
What's wrong with your waterblock though? That CPU temp is HIGHHHH for watercooling, specially with that low of voltage.
Tried reseating it lately?
Originally Posted by FragTek
roger that.... My temps are 42C loaded with Zalman 9500 on my Opty @ 1.45v. put some tension on them springs:D
I modded my HSF mount to a "through the mobo, stud design" and use knurled nuts to hold my Zalman on nice and tight.... kinda just like a waterblock, but using the Zalman mounting mechanism instead of springs on the studs. I can dial in some pressure with the nuts to keep pretty good contact on the CPU.
Dual priming @ 2.75Ghz, 1.45V!! 100% CPU usage baby!!
My DFI mobo is very crap :mad: . She alway incorrect detected the temp.
When i used the ninja or DangerDen water, the temp. is same :stick:
Ahhh IC!
I was going to say... lol
With my outdated Swiftech MCW6000-64 I top out at 38*c full load @ 1.7vcore. :toast:
Which should actually read ~ at the very least 48c due to the eXpert under-reporting temps :(Quote:
I have a temp probe fitted to the top edge of my 170 IHS which reports max 38c when dual torture PRIME95 v24.14 large FFT's and the eXpert reporting only 36c :rolleyes::slapass:
I wonder what the true core temp really is :eek:
tankguys.biz have the Opteron 165 0550 UPMW in stock now
Very nice chipQuote:
:toast:
do u have any results with the 165; your is a CCBWE 0551VPMW? I've found CCBWE 0551WPMW in the UK and trying to find out wht to expect.
This isn't on my Expert, I haven't migrated to it yet, this is on my SLI-DR (standard).Quote:
Originally Posted by alpha0ne
Originally Posted by mongoled
Hi guy, the results is good for me :D
2.7G@300*9, vcore 1,5V stable Prime.
Hope you got better result :toast:
How would you compare this with your 170? Was prime95 run on your default cooler? From the details you have given it looks like the 165 is good chip but nothing specialQuote:
I think the 165 0551 couldn't compare with this 170, I have the "lucky 170" :DQuote:
I'd tested them with same detail, same setting and SP2004 soft (sorry not Prime).
- With default vcore : 165 stable 2.52@280*9 but 170 not stable 2.5@250*10 :( .
- But with 1.5V vcore : 165 stable @300*9 and 170 stable @300*10
just opened up a CCBWE 0543TPMW opteron 170... cant wait to see how she does :D
I bought this one from ebay and didn't expect too much from it, but holy smoke big surprise batman this beast is truly Shock and Awe :slobber: :slobber: :slobber:
OSA170DAA6CD
CCBWE 0550 UPMW
1387408L50589
The IHS is still on...YES ithe sucker is still on!!! This stepping reminds me of my single core 148 CABNE, it has EXCELLENT memory controller as I can use the exact same timing as the CABNE wherea in the past I'd always had to relax the timing for all my X2 :eek: the 0546 XPMW that I received from ZZF last friday needed 1.63v to do 3.0Ghz, 1.60v always result in core 1 failed prime instantly....won't even last 2 seconds! Since the newer 0551 stepping is starting to hit the street and their overclockability is still unknown I'll see if I can get my hands on few more of these 0550 UPMW :slobber:
3.0Ghz @1.40v baby!!
http://www.xtremesystems.org/forums/...chmentid=42761
I haven't try lower vcore or higher clock, it's still priming at the moment but I'll yank the IHS later and see how far I can push this beast!!
:woot: :woot:
i cant help but notice that your cpu temp is 1C, i would be impressed if this was on normal air, or possibly water, but it looks like your cooling is even better.
Im currently dual priming at 2.8G with 1.48vcore on stock shuttle air, super PI 32m already passed.
