Welcome Jakup to XS, nice rig.
Your moving to DD from a Swiftech?
Damn EXA beat me to the punch
Generally people go the other way around (tdx->apogee) to get rid of the horrible mounting and the plexi tops and see an increase in performance...
I really don't like the apogee... the plastic barbs really suck, not to mention it already leaked once :( This is for my Conroe setup though.
Maybe if the TDX is that much worse I will cancel the order, I have done so much reading today that the TDX/Apogee really seems like a toss up depending on who you talk to.
cant you just buy metal barbs?
I know the wooden box and rubber made res are ghetto, but I am pragmatic. I would rather have performance for less. The larger the res, the larger the volume of water, and the more heat it can hold.
http://i47.photobucket.com/albums/f1...aterBlock2.jpg
http://i47.photobucket.com/albums/f1...ocardblock.jpg
http://i47.photobucket.com/albums/f1...k/DSCN0008.jpg
http://i47.photobucket.com/albums/f1...k/DSCN0007.jpg
http://i47.photobucket.com/albums/f1...k/DSCN0006.jpg
http://i47.photobucket.com/albums/f1...k/DSCN0005.jpg
might help to actually ahve the fans up against the heater core then?
I'm afraid water volume in loop has no effect on temperatures. Just takes slightly longer for them to reach equilibrium once the load changes.
As for the 'pogee barbs, just get G1/4 barbs (DD G1/4 HighFlow) and use both the orings that come with those barbs and those that come with the apogee's plastic barbs. Its what I do on my storm.
No, actually the way they are is just fine. I have 2 on each side, each rated at 96CFM. There is plenty of air moving over the surface of the radiator. Putting the fans on the radiator blocks the center where the fan motor is.Quote:
Originally Posted by trance565
I think what he means is that with big fat opening between the fans and rad that isnt sealed 2 of those arent actually doing anything, on account of air takes the path of least resistance.
Volume certainly does have an effect. If you radiator is removing less heat than your processor is adding to the system, it will take longer for the water's temperature to rise. This will take some time, and as I don't leave my system on 24/7 it works quite well.Quote:
Originally Posted by creidiki
I have tested to see how much air is pulled from the top. It is quite small. I put a piece of paper over that hole and it was hardly pulled down.Quote:
Welcome and glad to see you posting here. What "Chipset" cooler do you have on the way? Like you, I will be running Quad soon and there isn't much room on the DFI boards for a chipset cooler. So, I am curious to see what folks are using. I have a Forcetake Chip Force Chipset Cooler on the way. Hopefully it will work/fit.Quote:
Originally Posted by jAkUp
Nice rig BTW.
Its the DD Maze4 chipset cooler.
I'm not going to be using it on my DFI board though, I am getting these parts for my Conroe setup :D
Well the Jing Ting fit in Quad SLI? Doesn't look like much room, I was thinking of maybe slapping the Jing Ting on the SB with the Conroe board.
My case collection over the years
My first case Thermaltake
http://marcin12.home.comcast.net/1.JPG
Second Antec p160
http://marcin12.home.comcast.net/2.jpg
Third Cooler Master Stacker
http://marcin12.home.comcast.net/3.jpg
Forth Antec P180
http://marcin12.home.comcast.net/antec.jpg
Fifth Lian LI G70
Under construction
well its tucked in buddy. to fill i just pull it out, remove the cap and stick my funnel on the end, voila. sits there while its bleeding and filling np. thanks for the clap! looked cleaner in its hey day too!Quote:
Originally Posted by Grinch
next time im puttin the fill line right on the pump, in the extra inlet port wewt!
jay, so now you can play 1 extra round of cs.... :rolleyes:Quote:
Originally Posted by pauldovi
Well dam so you mean I got a 35 Gallon aquarium all insulated and riged to the chiller for nothing!?
LOL Jking, though the chiller pulled down 12 liters to 0C in 39Minutes and thats with a crippled chiller cell and frozen over coils! so it will rock when don, and when the chiller isn't running the cell subs in as a res with an air auto purge.
But he is right, more thermal mass makes for happy system and stable temps with less flux.
:banana:Quote:
Originally Posted by eXa
Nah, my radiator can keep up with the heat input from the processor most of the time. But when the CPU is under highly intensive stuff there is more heat put in then taken out. The res takes care of that. With the new C2D, I doubt I will have this problem.
My latest waterblocks:
CPU RF:
http://i6.photobucket.com/albums/y210/p0stman/cpu1.jpg
http://i6.photobucket.com/albums/y210/p0stman/cpu2.jpg
http://i6.photobucket.com/albums/y210/p0stman/cpu3.jpg
NB DF:
http://i6.photobucket.com/albums/y21...n/chipset1.jpg
http://i6.photobucket.com/albums/y21...n/chipset2.jpg
http://i6.photobucket.com/albums/y21...n/chipset3.jpg
VGA DF:
http://i6.photobucket.com/albums/y210/p0stman/vga1.jpg
http://i6.photobucket.com/albums/y210/p0stman/vga2.jpg
http://i6.photobucket.com/albums/y210/p0stman/vga3.jpg
I hope they like you.
Greetings.
Mion..is that a dual rad in the P180
That's some great work! And hopefully they like me, i agree ;)Quote:
Originally Posted by postman
i think it's the thermochill p160 in the antec p180. has a nice ring to it j/k, no i'm not.Quote:
Originally Posted by nealh
Looks like a PA160 and some form of HWLabs X-Flow abomination =/
@ postman... do you have any worklogs of making those blocks? Would be interested to see your process.
Those are some really nice blocks man, what temps you get with them? And to NealH, it's a dual rad on the top (don't know which one) and a PA160 on the front.
Usama aka Ferrari Freak
