The trick I use to get the tray icon to appear is just mousing all over the 'Show hidden icons' arrow and the first tray icon until it shows up. Sometimes I have to run EasyTune two or three times AND use this trick to get it to show up.
Thanks, but I do not get any icons. what I get is the following message while loading vista:
"GUI MFC Application Has Stopped working"
* another issue is tha I have C1E and EIST enabled and some how my multy never drops to 12... it must be some other stetting that is interfering in these ones.
I have the same problem with EasyTune. Neither the one from the CD that came with my mobo nor the latest version from the web site will run, both erroring out with the same error that euonline is getting.
My easytune that has worked flawlessly on every installation i have done since getting the board has suddenly started crashing on startup as described.
What has changed? I downloaded the latest version from the GB site ;)
Since i never even used it to begin with i'm not even going to bother reinstalling the one from the driver cd.
easytune B8.1224.1 loads at startup for me in vista64 :shrug:
I live in Canada and it's just a cold or colder here. I'm not grumbling, I just had no idea where you were from and that english wasn't your first language. Chill the eff out, and stop quoting my name in your posts like I'm after you.
Beautiful clocks by the way :)
Just an FYI for all Gigabyte UD5/xTreme owners, I was getting "IRQL not less or equal" error with Green Lan Feature enabled when running Prime and Linx. I disabled that feature and the problem is Gone.
Find a small bug in the F5C, E and G bios for the UD5.
CPU FAN settings goes back to auto every time you enter the MIT page. :D
Seems i need to retests my settings with F5e
Just got a BSOD while playing TF2, guess its the ram/imc. Since with each bios version the subtimings change.
So I have pretty much settled down to two motherboard picks that I want. Either Asus Rampage II Extreme or Gigabyte EX58 Extreme.
I am posting here to ask if 12GB of Corsair Dominator Ram TR3X6G1600C8D that they have on Newegg will work, stable and run well at 1600MHz. I know by looking at the QVL doesn't list the memory, sadly.
I really like the layout of the EX58 Extreme, it's loads of SATA ports and still support triple SLI and I can toss a Fatality sound card in there if I get bored of onboard. If I get the EX58 I will be Watercooling the board so even though the heatsinks are sweet I will be actually removing them.
I am not sure if the Extreme is the same as the UD5 with more pipes or what, but either way I will be removing heatsinks. *searches for his chainsaw*
But yes, the real major issue is can I run 12GB of those ram at 1600MHz with a 920 i7?
Someone mentioned in another thread that no Asus board has the "Turbo" feature, which basically gives you an extra multiplier. If this is true, I wouldn't even look at the Asus.
Still no one that has even tried raising PCIe to say 110MHz on EX58 Extreme...?
is it still just possible to change ram-timings in bios ? No memtweaker in windows works yet ??
It's not a matter of should mate, it could be a matter of necessity depending on what kind of clocks you want to hit. Standard is much, much more forgiving from what I've found and although Turbo gives you a small boost in Everest cache and bandwidth, it's small enough to overpower with sheer clock power.
I haven't been following the Asus board thread but I think I heard that a BIOS update is coming soon to add an option to disable the TDP limit requirement for the turbo multiplier to activate. Right now Asus users can keep turbo active (21 multi on the 920) as long as they don't OC past this hard coded limit that they are temporarily stuck with. This isn't an issue for 965 owners because they can manually set whatever max multi they want and not care if turbo works past a certain clock speed.
