Originally Posted by
mikeyakame
Good stuff mate :D
I've seen quite a few MFs needing a lot of Vtt so I'm not surprised. Thats good news anyhow, all you can do is find what works for your board right.
Other thing is Asus reads Analog Vtt, which isn't all that much to go by as you increase Vtt voltage. Vtt voltage at the pins is a decoupled voltage, Analog Vtt is decoupled with Digital Vtt to give a final Actual Vtt voltage. I've heard of upto 0.1v difference at the pins with high Vtt voltages. So if you find you need that much Vtt, it's possible the actual Vtt voltage at the CPU and NB land pins may be much lower than what you are setting.
I got my DFI X48 board up and running last night, and there is two things I miss already with the RF.
1) LCD Poster, hell makes life so much easier than looking at a diagnostic display on a board mounted inside a closed case!
2) Phoenix bios is nowhere near as overclock recovery friendly as AMI bios on Asus boards. Rebooting during a post or a locked POST on the DFI board doesn't trigger default settings on next POST. The "home" key is supposed to do this, but since I use a bluetooth keyboard primarily this makes it impossible to hit "home" to boot with defaults. It hardly even gives me enough time between USB Finalize when USB devices are active and INIT Option ROM stage to hit the "del" key to get into setup! I had to turn quick boot off so it runs a long POST memory test to get the time to enter setup!
Other than that it's a nice board so far, definitely no where near as friendly as Asus boards for overclocking with a closed case that I can say for certain!
Edit:
Hopefully this time I write this post prime95 wont lock my system uP! :rofl:
It's a fun board so far, bios is extremely flexible and learning curve is steep, I'm liking it. Though it took me 2-3hours just to get my ram stable at 1066mhz ! heh. Figured out the set Vdimm is 0.08v higher than the read Vdimm.
Giving up for tonight cause I need to catch up on work sleep! Still haven't got 333Mhz FSB stable yet! :rofl: By stable I mean to my own acceptable performance and not locking up while doint it :D
Kinda makes me realize how much we take for granted with Asus boards. The bios does half the work for you, just you dial in numbers and presto very little work for stability! I can dial in 400mhz FSB on my RF without even hardly touching a thing. This DFI board is lucky to get past POST if I set 333mhz FSB and don't play with voltages, timings, and all that stuff.
Speedstep works well though so far. The Special VID Add option is nice, lets you run VID voltage + percentage on top. I believe it's so speedstep doesn't break like on every other board when you change Vcore.
Fan Control works perfect too. You set minimum temperature for fan disabled, which is < 25c, then you set max temperature where fan is 100% duty, which I have 35c. So between 25 and 35c the fan duty is increased linearly on a gradient line. Hell my 2700rpm 51dBa 135-140cfm 120x38mm Delta runs at 8-900rpm on POST and whenever the CPU is idle :D It's almost quiet now heh
Hell I'm almost tempted to throw my 65dBa 235cfm 120x38mm Delta onto my TRUE if fan control works this well.
I tried running it once on the RF and I removed it after 30seconds because the bios wouldn't run it any less 100% duty! It sounds like a wind tunnel at 100% duty. I once had it sitting on my desk for open case benchmarking and forgot to secure it to something. Turned the system on and it launched itself a good 0.75m off the desk! Ripped the connector out of the power cable toO!
Oh one last thing. The DFI bios sets tRFC correctly! First board I have seen to actually do this.
Memory Bus 532.3 MHz
Refresh Period (tREF) 4171T
tREF is 3120T for DDR2-800.
