Originally Posted by
TheRoyalty
Sorry lads, should have posted them up earlier. Voltages are currently being fine tuned but so far here's how it stands as we speak:
FSB:1800Mhz 9x450 - Linked & Synced
Vcore:1.4875V (Bios) 1.456V (CPUz)
PLL:1.60V
VTT:1.30V
MEM:2.00V
NB:1.58V
SB:1.60V
LLC: Enabled
GTL REF 0: -.29V
GTL REF 1: -.32V
GTL REF 2: -.32V
GTL REF 3: -.29V
Memory: P1 & P2 - Enabled 7-7-7-20 2T (Rest on auto)
Temps: CPU Idle 32C CPU Load 65C GPU1 Idle 35C GPU2 Idle 36C GPU1 Load 46C GPU2 Load 47C NB Idle: 48C NB Load: 55C SB Idle: 46C SB Load: 54C
CPU Config: All Disabled except for the following - CPU Temp Control [Auto] All cores [Enabled]
Spread Spectrum: All Disabled.
As always the rule of thumb, these settings may or may not work for all so use them as reference only. Every other setting that I haven't mentioned above is on AUTO. So far for now everything is smooth, no SLI lockups or corruption issues, OCCT, Mem tests & Prime stable. Gonna sit back and enjoy the ride...for now.;):D:up:
