Originally Posted by
Jor3lBR
Well I never said I dislike my OC, on the contrary I'm all set with it and also running cool in the mid 20's idle and 30's when 3d gamming.
And yes to run this cpu/mem/mobo combo fully 3D stable with a mem reading above 10000Mb/s 1.5v is low (from MY point of view) and it is 24/7 settings. The processor can outlive me running like that everyday...
But once again if you ask me if I'm satisfied with the mobo entirely I'm not. Starting with the crazy volt readings and the quickie patch/crappy bios to fix it (1/11), going thru some cold boot issues (turns off and on and then needs reset from now and then). It's like buying an expensive new car and discover you have to spent 1 month in the dealership to fix pre-existent flaws.
Maybe with mature bios I will be more satisfied with it.
But I don't get the fuss about my posts, this does not even has anything to do with anything. Someone asked about opinions of the mobo/quad combo, and as a real user of 2 of those combos I gave my sincere opinion, unlike you guys...
