Is this good? Do I need to enter anything or just wait?
http://img113.imageshack.us/img113/3...4088an7.th.jpg
Is this the right battery?
http://cgi.ebay.com/For-5-PC-MotherB...QQcmdZViewItem
Thanks for all your help buddy! =)
I'm half way done.. Ill let you know how it went when I'm done!
Go back to previos Page and Follow Instructions ...Please!
Ok all done! But the problem with the C1 remains... what I mean is that i set up the voltage from 1.9 to 2.2 and each time I shut down windows and let it sit like 1 min and try to boot it up from the case button it goes C1 and shuts down no matter what I do... the only way I can boot it up is if I press the power button on the MB and press down the DEL key... and the first time it does not start only on the second time I try... any suggestions? Thanks about the bios update I manage to get it!
By the way I followed the instructions just like you said! Anyway I can check anyways what bios I have? Where do I look? Just to make sure... thanks!
n00bstorm where are you located and where did you getthe board from and when you RMA'ed it did it come back from supplier or DFI?
I got the DFI board from newegg and it come again from newegg... Ill get CPUZ on there in just a sec and let you know!
Ok on CPU-Z says that the bios are updated and also when I went to the bios the voltage on the RAM was back to 1.9 (default) even do I changed them and saved them? May the battery have something to do with this?
Why don't you stay still and focus so I can help you if you are having problems?
You try all 3 different sets of Ram?
The ram right now are in slot 1-3 and I'm using the Corsairs 1066, now all I did is change the voltage in the bios from 1.9 to 2.2 and also there is a option there were is default at auto I changed it to 333/1066 and saved it. Now whats wierd is when I try to turn on the computer from the power button on the case it just does the same old story C1 and shuts down... I need to press the power button inside and hold down the DEL key in order to get the system to boot!
Have not try'd the other ram... sense I was able to boot the bios with the ones I have in right now the corsairs
Gotta use you're common sense man! See if the other Ram works better quite possibly it could you know?
What Ram are the other Kits, Please?
The Crucial Ballistix
http://www.newegg.com/product/produc...82E16820146565
Should I snap them in and try again? See what happens?
Yes set bios to Vdimm 2,0
And change to the Crucial's? or leave the Corsairs inside?
Cmon Bro:rolleyes: pwer down the system unplug the power cord clear Cmos for 15 seconds Remove Corsair//// Replace with CRUCIAL:welcome:
Ok doing it right now...
Same thing with the Crucials!
Get a Bios Chip or send the Motherboard Back! Try a Abit IP35 Pro there great boards and even you can overclock it
RMA the motherboard again? That's going to be once again pain for the next week or so...
By the way I just figure out that the power button on my Thermaltake Armor its indeed wierd and I think that is also a problem. What I mean is when I press the button it goes inside and when I press it again its hard to pop out... I need to use more pushing power and press it harder in order to get out...
:shrug:
Also when I just tap the power button and it does not even go in the computer starts right up...
:shrug: :shrug: :shrug: :shrug:
I'll deal with it more tomorrow ill go to sleep too! But Esau I'm more then greatful for walking me thew each and evrey step of the way great help! Thank You!
:up: :up: :up:
