may be early next year:DQuote:
Originally Posted by tictac
LOL -> You believe in :eleph: too??
i've got one of those pink elephants in my backyard. You dont believe me? :p:Quote:
Originally Posted by Nitemare
Hipro said the 1333 strap really didnt help his initial results much. So if thats what your waiting for your most likely going to be disappointed. Maybe beta bios 1.3 version 28 will finally make us happy. For me, im almost at my breaking point. I need a P965 board soon or im going to loose it. I might be going commando too.
LOL, everyone's almost jumping of the boat on this one ..
:dammit: ABIT, you'll gonna end up with a ghost ship !
:D
Tried both and no success. I think i am the unluckiest mo*******ker here on XS. Bought a mobo that wont go over 360fsb+bought a crappy e6600 that needs 1.5Vcore for 3.2ghz.:(Quote:
Originally Posted by coop
Okay, hope I am not shooting myself in the foot. I have never really been concerned with 400+fsb on my board because I had a 6800 running 387x11 no problem 24/7. I came across a 6700 for a super deal so now I am going to sell the 6800 and put a few pennies back in my pocket for c2q eventually. I am hoping I can get close to the same clocks I was getting with my 6800 (4.25ghz stable 24.7). I don't have the chip yet, but have been trying to get 425fsb blend running 10x425 on the 6800. By the way I am running a mcw30 on the chipset right now. Orthos hardly makes it 15 minutes at this speed. However....
The new multi threaded prime95 made it close to seven hours. Check out eva2000's post if you havent already. Might prove to be a little more useful than orthos. I set prime95 on priority 9 for the screen shot below. I will let you guys know now that I am in the fsb challenge as well. Hoping new bios or strap will help but so far that doesn't look good. P5B is looking better and better by the day, I just hate to have to re-insulate a board. This was my first time insulating and I nailed it spot on, no issues for 2 months so far.
http://www.auction-junkie.com/pcstuff/7HRSBL_TH.jpg
heres mine X6800 -abit aw9d-max well rigg in sign.
a little better fine tuning and i will get higher in everest read..
http://img169.imageshack.us/img169/3...las2no1.th.png
http://img172.imageshack.us/img172/1...est3sd9.th.jpg
so far i'm satisfied with my board...
SilveradoJ442 what sort of extreem sticks do you have is it the same as mine perhaps??
And wich bios is the best to go for real overklock??
I am actually using the Team 667 Sticks HereQuote:
Originally Posted by chefnr1
They have actually been working really well for the past 2 months @ 4:5 483mhz 4-4-3-7 2.25v. They are great sicks for the $ :)
Not totally sure, right now I am using the beta that released on 11/23/2006. Anyone know if there is a better bios atm?Quote:
@chefnr1: That is a nice FSB you have there. Where are you stable at with the vmods? I guess I will have to look into modding my board soon
i have'nt run that high yet but i think i can manage near 500 fsb if i tuned in mch and vfsb and mem volt atleast i hope so, my EXTREEM are pc2 6400 4-4-4-10 but i can run them at 3-3-3-8 but not that high on that speed i reach about 440-450 fsb after that i have to loosen the timings, and i always run them at 1:1 no divider at all...Quote:
Originally Posted by SilveradoJ442
Can anyone tell me if it can be a CPU matter or if modding the vfsb would be worth it?Quote:
Originally Posted by JaD
I was planning to get a new board because of that limit, but if it's the cpu...i would just trash money :\
Thanks for any idea! :)
yes maybe vfsb mod could help you, but my board do unmodded 440-445fsb, and when i set mvch to 1,80v vfsb to 1,45 i can reach a bit higher so it maybe help you with you're issue...Quote:
are you sure you measure out the real volt from spots on the board so you dont trust bios or other volt program..
Can someone post a link or pics with a "how to read vcore with multimeter for dummies" in this board please ?
Look in this thred and you will find mods..
http://www.xtremesystems.org/forums/...=abit+aw9d-max
For Conroe, this is my board! But for Kentsfield, I am still with a trusty and reliable Bad Axe 2.
I hope Abit improves their board better in their future boards. These new bios is just so freaking long to release, it's not worth the wait anymore.
I will relegate this board as an uber Conroe board, but not as good for Kentsfield.
i've tested kentsfield on my board not so lucky with that, theres no support for quad on it..
Anyone here ever have a problem with the Max not seeing a USB HDD ?
question, what if memtest gives you no errors...super pi 32m goes thru w/o an error...but running 2 instances of super pi 32m at the same time errors out "not convergent in sqr05" (the 2nd instance usually errors out). What do i make of that?
edit: i also get errors running the windows version of memtest (hci memtest).
Im currently at 378fsb, 1.35vcore, 1.70mch, 2.2vdimm...about 35c idle, 45-47 load.
edit2: nvm, i ran memtest overnight and got errors in test 2, 3, 4, 5, 6, 7 and 8....:(
thanks
i've just put in my x1950 master card yesterday, question is there something in bios that i must changed so that it run properly, tested 3dmark 03 at 762/1082mhz and only manage 35800points cpu at 3760mhz all on air ofcourse, if there's someone who know's that i'd appreciate help very much.
Thanks...
EDIT and the master runs very hot but that could be so that it maybe nott get that good cooling as the slave, i have modded on a cpucooler and mem hs but mem runs hot aswell, when slave mem is totally cold...
http://img241.imageshack.us/img241/9...5814ix1.th.jpg
http://img183.imageshack.us/img183/7565/05iw9.th.jpg
Move your superpi.exe in two different folders.!!!!!:slapass: (I had the same problem)Quote:
Originally Posted by <><
For windows memtest errors try uping mch voltage and vdimm.
is not in santas bag, :DQuote:
maybe at next haloween :cool: :mad:
Ah, didnt think of that. Well after getting a ton of errors on memtest last night in dual mode, im gonna go home and test out each module individually and see what i get.Quote:
Originally Posted by Varsos
BTW, u and me have almost the same system :banana:
edit: another question, when im doing the OC, is it ok if i change the voltages etc thru windows uguru and then testing again? Or is it better to restart and go into bios and change it?
Guys,
got this mail today:
DOWNLOADQuote:
Bios 13 Final / release bios,
1. To support Conroe-L CPU(FSB800)
2.Modifying memory default voltage at 2V after clear cmos and if user choose DDR2-800 memory, DDR voltage will set on 2V automatically(By SPD ro Manual)。 DDR533/667 are staying on 1.8V (By load optimized default or manual)
3. To support Conroe Extreme (X6800) CPU's Multiplier range from 6 to 31
4. Update CPU micro code to support Kentsfield B3 version
5.Added DRAM timing option "Refresh Cycle Time (tRFC)"
6. Fixing OC Guru DDR2 SDRAM Voltage to DDR2 VTT Voltage
7. Fixing some DRAM performance decreasing issue
8. Add Thermal Control option
9. Fixing OCZ DDR2 1000 boot fail when set it on DDR2 533 issue
10. Fixing External clock over 365MHz, POST shown wrong Host/Memfrequency
11. Fixing CMOS loss all data back to "fail saft model" issue
12. Change AW9D BIOS setup menu color
13. Remove Memory Frequency on post
14 Remove PCI Express slot 2 item in BIOS
Flash on your own risk!
so with a Kentsfield B0 version it will not work, i can only run a B0 version at multi 10 over that just blue screen...
Hmm no 1333 strap?
Is the strap in this one?
