Hm, I seem to have the same thing. I'll be damned if I know what it means, though.
Oh, and as far as I can tell, I have no video issues.
-phil
-phil
have you install the latest intel chipset driver?
http://downloadcenter.intel.com/scri...=2261&lang=eng
I have the latest chipset drivers installed. So, syne_24, your SMBus controller has a driver installed? On my General tab it says there is no driver present. Presumably, the same situatiuon as Jungle+=.
-phil
I have the same supposedly resource conflict, however I haven't noticed any issues with my video.. Sadly you had to show me this... Maybe I can just forget about it.. Lemme find some liquor... :)
well i'll be damn i got it too..lol..lets see if anyone else has a fix..
Mmm.. more A5wDH secrets uncovered :rolleyes: yes i have it there as well.
I wonder if this SMBus controller is some legacy device, no longer being used.
-phil
Yes...I have the latest 975X drivers installed directly from Intel's site (V.8.1.1.1001) . In the driver details button pop up for the SMBus , it says that I don't have a driver installed for it .... however the driver it shows above the button (V. 7.0.0.1020) is an Intel release from 23/05/2005 . The chipset INFINST.exe does not update it .
I could also confirm Jungle+= 's issues on my system running 1503. What I'm curious about is if this is also manifested in the previous BIOS builds?
I have exactly the same I/O thingie on the SMBUS but I really, really wouldn't worry about it IMO.
Yeah, due to the height of it I am having second thoughts about sticking a fan on it as I think with the mobo standing upright, the leverage pressure on the chipset core will be more than the clamping bracket can keep directly in place. Vee shall see.....Quote:
SMBus Controller = ChipsetQuote:
Originally Posted by phile
Intel Chipsets don't need drivers..
The only reason you install the Intel Chipset Installation thing is to "TELL" windows that certain things are there to be used. SMBus doesn't need a driver, just windows has to know it's there to be used.
I have the default 0701 Bios version (which came with the board that is rocksolid for me ) and have the same "issue" in device manager.Quote:
Originally Posted by Bloke
Wow. Funny thing is I thought I knew my system inside and out. I had no idea this was even there (or not there??)!
i have 1402 and the same issue.Quote:
Originally Posted by ROCKSOLID
I'm planning on upgrading to 1503 today, 1407 gives mem timing problems on my rig, anything other then spd and i can't overclock (can't post, need cmos clear and the damn battery is under the 7950gx2!!!!!)
Read the first page?Quote:
Originally Posted by catscit
1503 won't fix it bro
I built the rig in the sig a few weeks ago. I'm very happy with the performance and the OC is Orthos stable at 22.5 hours, the longest that I've let it run.
I had a problem with S3 standby from the very beginning. Stock clocked or over clocked it would crash coming out of standby 100%. Hibernate would crash and restart sometimes going in and would crash and restart about 50% on resume. Very frustrating. I was blaming the video drivers since my previous build (AMD/nvidia) would sometimes not reinitialize the display coming out of standby and it definitely changed behavior with different video drivers.
Yesterday I found http://support.microsoft.com/kb/889673 and installed the hotfix. Standby works perfectly ever since!:clap: I have not tried hibernate again, since standby works so good now.
I hope this helps others who were frustrated by this issue.
Is running 1.85 vMCH on air really bad. Because I dont know I tinker around with the ram volts and core volts but when i raise the vmch up to 1.85 i can stabilize at 400.
The screenshot looks OK: what looks bad on your monitor?...Quote:
Originally Posted by Jungle+=
Anyone know what is aux temp in speedfan for this mobo? its giving me 75c and i have no clue what it is.
The third temperature input is not connected to a sensor and reports bogus data.Quote:
Originally Posted by hyperdoggy
Well I have been running my rig for about 5 days now. Everything seems to be ok with the exception of a low 3dmark06 score on the video side. Not really sure what is going on there.
http://www.differentracing.com/john/6194.jpg
what driver are you running?Quote:
Originally Posted by my65bug
my score increased by 50% after installing 91.47 (from 5500 to 8500)
Ya know what... I dont know. There was no cd in the box I got so I had to download all of the software off asus's website. Where can I check the driver version?
