I' d just got Opty 165 with stepping CCBWE 0551 VPMW (new week ^_^)
I''ll test it toninght,
@imax, @003 Where did u guys get yers ??
I've got a 165 0550 UPMW that primes for hours at 2700 @1.4Vcore that I'm thinking about selling to fund a 170 so that I can take better advantage of my memory's sweet spot. PM me if you're interested :)Quote:
Originally Posted by noktekniq
Dogs has two 0550UPMW's that do 2700 at stock voltage!Quote:
Originally Posted by 003
shot you a message. i hope i can get like a good cpu. i'm gonna get rid of my 170Quote:
Originally Posted by ErikaeanLogic
wonder if ZZF still has 0550 UPMW ..... anyone get one very recently? I'm thinking about grabbing another one and keeping the better of the two.
Việt Nam ;)Quote:
Originally Posted by nugzo
so far so good :D
I got mine from ebay.Quote:
Well bought one 165 cbbwe 0550upmw new on e-bay.....hope I will have the same luck as you guys.
Just recived my 175. ccbwe 0550upmw.
http://student.umb.no/~astorp/Images...%20175%202.jpg
MB: DFI Ultra D Bios 623.3
MEM: 2 GB Ballistix Tracer
Cooling: Thermalright XP 120. Soon to be water ;)
See, like I said, with dual-core Opterons a stepping doesn't matter as much as single-core Opterons. (Maybe except those 0530TPMW) Nightprowler's 148 does 3160MHz on ASUS but the 175(!) does 2607MHz @1.45V. There seem to be alot more factors that get involved than steppings. My guess is motherboard + BIOS + Dividers + Multies + Temps + ETC. :D
My 0547TPMW does 2808MHz (9x312) @1.42V (Air-cooled). So far most consistent steppings that I've seen are 0530TPMW and 0546XPMW.
The 148 is water cooled (Switech Storm BIX3 rad) and the temps are low (40 Full load) compared to my Opteron 175 (54C) full load.. Haven`t tested any higher than 2.6ghz cause of the temps, but it`s stable as a rock.
On default vcore I could Prime at 2.5 ghz but had to increase all the way to 1.45 to get 2.6ghz stable…
165 CCBWE 0550 UPMW
(2.75GHZ) 2745 Mhz
10 HOURS DUAL PRIME STABLE!
Think I need to pass S&M to qualify for stable?
Hi!
I have a problem with StressPrime:
I have an Opteron 175 so i launch two StressPrime and then set manually the affinity both in the prog and in taskmanager---> when i start, the first StressPrime effectively stress the 100% of core, but the second only stress 5-10% of the second core...
The same happens with Prime95 torture test - blend (and StressPrime is in fact the blend torture test of Prime95...) but not with the others two options of torture test.
Rename the exe files and launch from different directory does not help.
How can i solve this?
your saying that you have copied the whole prime folder (or SP2004), and run both exec's, then selected a different core to prime on each seperate program?
If you have then im stumped.
All that i have is SP2004.exe
When i start the prog create ini files.
I want to run this prog on each core stressing 100% but i can't: for some reason only the first exe launched stress the cpu core at 100%, but the second copy stress the other core at 5-10% in media, randomly at 100%.
I tried to rename the file and also to start each exe from different directory, same result.
Someone can tell EXACTLY what i must do for running StressPrime on each core,stressing 100%?
CCBWE 0546 XPMW
Shuttle SN25P
Stock shuttle AIR cooling
Stock vcore
http://img491.imageshack.us/img491/6...pmwat26002.jpg
Priming to come tomorrow
Hey guys I just bought a Opty 165 from someone who said it ran flaky on his MB at default mulitplier. He had to drop it down to 8x to get it to OC. I got the chip for $240 shipped and it's only a couple days old. Did I do well?
This is the reported stepping i'm getting CCBWE 0550UPMW
You did well as long as it's not a "flaky" CPU. I personaly would not have bought it if it was described the way you described it.Quote:
Originally Posted by shoman24v
Im thinking of buying a 165 from monarch, with Dualcores does it matter OEM vs. retail? I plan on getting whats cheapest , just wanted your advice.
The processor I sold him isnt flaky at default clocks its flaky @ 9x300. lol whats up, whats the likely hood i catch your post here
:D I'm excited, i'm not worried, I know the CPU will be good :p: just hope my mobo can do a high FSB :stick:Quote:
Originally Posted by foch3 -USA-
This is my first attempt at overclocking but so far I'm very pleased with the results I'm getting. I'm new to this so please excuse my ignorance :) I have a few questions. First, My PWMIC Temp goes to 51-54 when doing any kind of benchmark and I'm concerned because it appears in Red? Is there any type of add-on cooling device I can use to lower that? Also, why in my SPD page of CPU-Z do I see two different frequencies and timings.? Overall, I can't belive how well this system performs. I have a dual opty 252 and in just about every application I use this system performs as well if not better than a machine costing substantially more.
I just got the same as iMAX! Mine came from Rainbow-IT here in the UK.
ok 0550 umpw retail box from newegg. dual priming as we speak out of the box first boot at 300*9 for 2700mhz. 121 fahrenheit 49 celsius while priming. air cooling w/zalman. If i dont get any higher i'll be happy.
