Originally Posted by alexio
If you find another one that does (280x9) , let me know . Would you sell one of those :D . Hard to find chips that accept more than 250 fsb
I would love to but I don't like to ship all the way from europe to Brazil. If I can't sell them in The Netherlands I will let you know.Quote:
Originally Posted by toledo
I forgot to say , i`m in the US untill end of august (maybe september)for business . :D .Quote:
Let me know if you would like to do that , anyway .....thanks .
I can do 9*295mhz now :toast:
I'm now running checkdisk because data got corrupted. Finding the max of a Dothan means you get a lot of crashes because 24/7 stable is very close to a speed that crashes the system.
Next try will be 9*300mhz. At 8* multiplier I can't even boot and the system freezes if I try this in EIST; at 7* multiplier I can not achieve a high fsb.
I heard that the lowest multi that really works is 9 ,anything below this just does not work well , i don`t know if it is true .Quote:
9x295 :slobber:
On my P4P800SE only MP 9+ work.Quote:
Those high Fsb are motherboard depndend I can reach 305 with clockgen not 1:1 of course :p
So true...Quote:
I've concluded that the "fiddling" with MP and FSB is pointless other than to get the few last tenths in SuperPi.. and a few more points in 3DMark01..etc..
At some stage it just "hits the wall" as I've stated in other post(s). For me..with my P4P800 SE and Dothan 730..on good aircooling.. this is 2550Mhz.. It will bench SuperPi at 2660..but no 3D-benches will finish at 2580+..
I've also concluded that VCore over 1.50 is worthless (Bios 1009.004 alllows 1.60..., Bios 1008 gives 1.55)..
As of writing I'm "priming" the chip at 2550@1.50VCore.. for 24++ hours..
yes it is true
how about to the uk :woot:Quote:
Maybe I'll do that ;)Quote:
Originally Posted by ibby
I've tested 2 Dothan 740's from the same box now and they do EXACTLY the same.
9*295 = 2,65ghz
10*265 = 2,65ghz
11*241 = 2,65ghz
This is one ANY memory divider and they both don't like more than 1,425v. Could this be a mobo related problem :confused:
IMHO, unofficially LV ones should work (but I read some single maybe not so reliable report that does not boot) & should OC nicely (if won´t be there same 180MHz Fsb "barrier" as for C_M is), since would be overvolted by default. While you can not put ULV ones in, since are NOT Fc-Pga package (Fc-Bga instead = no pins!)Quote:
I have not seen any result with a 770 chip so far .
Does anyone know anything about this chip ?
all at the same speeds :nono: surly not all of these cpus max out at the same region ....Quote:
:slapass:
At 1,425v they did. I found out I need 1,5v for 2,7ghz (13*208) on my second cpu. I can't provide screenies now because I'm running in diagnostic mode because windows is screwed. In diagnostic mode it will not recognize a usb stick. I can't use more than 1,5v because my temp rises to 70 dregrees C* ( I need to put some thermal paste on :) ).
I will make a 9*300 Prime95 screenshot if it can do it
ummmmm - I get around 70C load at 800MHz 0.7V cooled by a ramsink (a little tiny 1.5x0.5cm copper one).Quote:
how do you get the temps so high?
what kind of cooling is that? at like 1.7V 2.66GHz full load mine will never go above 25C ('cept summer - ambient now 18C).
Stock cooler without thermal paste ;)
I don't know if I can trust the temsensor even a little bit.
770m is a bad-ass chip. They can run super high fsb at any ghz or multi, unlike the 780es.....or at least the one I have. A 770 with really high fsb and tight timings on p4c can match the 780's perfromance on ln2. My 770 is the current single card WR holder for x850xtpe in 3dmark 03, 3dmark 01, aquamark3, and #2 single card behind macci in 3dmark 05. Had all these runs been on my solid container, they would be much higher no doubt....Quote:
#2 single x850xtpe 05'
WR single x850xtpe 3dmark 03
WR single x850xtpe 3dmark 01
WR aquamark3 single 850xtpe
Also close to 19sec with it for sp1m......with some tweaks I recently learned, that sp1m is mid to high 19's:
http://pic8.picturetrail.com/VOL256/.../102678739.jpg
and here is a quick 8m...with higher clocks and better tweaking, it's prolly closer to 4 min easy:
http://pic8.picturetrail.com/VOL256/.../102245743.jpg
I saw your 01 score some time ago - you're not just the world record - you're like 4k above 2nd place...Quote:
Originally Posted by k|ngp|n
acutally my bad......I used 760m for 03 and 05 runs :)
01, am3, and pi were on the 770m. Thought for sure I re-ran them with the 2.13ghz chip, but I guess not.
Very nice :slobber: .Quote:
How far this chips (PM770) go on air ?
It did around 2.8ghz for benching with the ct-479 aluminum cooler.Quote:
So , for a air cooler maybe a 760 chip is a better choice , right ?Quote:
Just ordered a 770 and it is nice to hear good things about the 770,2.8 with ct-479 cooler soundz good
my best shoot
http://img224.imageshack.us/img224/8...n250fsb5fv.jpg
My 4th Dothan is really funny. Prime is running all the time while explorer.exe and system services keep crashing :D
Ik can do 2,8ghz now but at that speed explorer.exe keeps crashing, this is with the 13* multiplier. With the 11* multiplier I have a hard time doing more than 2,65ghz and with the 12* multiplier 2,7ghz is just about stable.
I must say the Dothan is the weirdest cpu i have ever OC'd.
Jep agree, 223*12=prime stable for more then 9 hours but sometimes it just freezes or crashes :D
