what resolution you was running ?
I ran same as him 1600x900 all same settings in heaven
@Rattle, thanks .
Anyway, the guy on OCUK report a weird thing, 706mhz as default clock ( i let you read their threads lol, too much pages ). nvidia control panel, GPU-z say the same. Dont know if theres different default clock or not. (outside turbo mode ) ...
I hope it's an error on reading the default clock.
http://img13.imageshack.us/img13/4623/sanstitre1oxa.png
GPU-Z 0.60
Added optional GPU-Z installer which launches when GPU-Z is started for the first time, or can be started manually via the GPU-Z system menu
Added support for AMD Radeon HD 7870, HD 7850, HD 7670M, FireStream 9370, FirePro V3900
Added support for NVIDIA GeForce GTX 680, GT 640M, GTX 560 SE, GT 550M, GeForce 510, NVS 2100M
Fixed clocks not showing correctly on some systems with Catalyst 12.2
Fixed board id reading on pre-Fermi cards
Fixed OpenCL detection for ATI Fusion (Sumo & Ontario)
Fixed GPU-Z window getting cut off at certain DPI settings
yep good find, and it have fix the report of dual gpu ,..
Now if someone can send it to this guy on OCUK lol ..
min fps mean nothing in Unigine Heaven if the tester doesn't cycle through all the 26 scenes at least once by pressing enter. Only then are the results realisting - streaming problems otherwise.
Yup it was recently brought up, he's running 300.65 not 300.99 as seen in another screenshot, he also need the newer GPUZ I think :)
Just apparead on Tweekdown, apparently the GTX 680 is listed at $566.75
http://www.tweaktown.com/news/23058/..._75/index.html
Looking forward to some noise results.. If it idles quieter than my 480's I'm sold!!
Title of this thread should be 680?
Yeah I posted what the original link was days ago in this thread. Likely a jacked preorder price but it's listed.
http://www.xtremesystems.org/forums/...=1#post5070420
From overclock.net again.
For reason the Heaven is showing the card as an intel IGP, although he says it might be because he ran it in Windowed mode.
http://i60.photobucket.com/albums/h2...3/7ef2e0b4.jpg
http://i60.photobucket.com/albums/h2...3/4e932bd0.jpg
^ link please? So we get the larger original picture.
Copy/paste the url's and it gives the original size:
EDIT: Notice it says release date March 22nd, which is Thursday... :D!
Thanks. 78 fps...that is 35% faster than a 7970 (57 fps):
http://www.forum-3dcenter.org/vbulle...postcount=6815
Impressive ^^
Someone with a 7970 care to bench? :)Quote:
Batman AC: 4x MSAA, 16xAF, Global Settings on very high, PhysX off (to compare to AMD)
112 FPS at 1300/6500 on 1920x1080.
(I assume he used DX11).
