Alot of people saying Fr bios.. but i actually found the beta bios F7B to be way more stable and more overclock friendly..
Does anyone know which three temps are reported by Speedfan for the UD7?
Temp 2 is almost certainly CPU. Temp 1 might be MCH. Not really sure on Temp 3.
Prolly not strange at all. The F7 betas introduce a microcode update for 32nm chips. While those may profit, us D0 45 nm users are likely better off with the well proven older BIOSses until F7 goes release. My D0 920 runs well at 21x181 now and 1.2875V...no way to achieve that on F7p or F7r.
I'm still all the way back on F4 with my 980
Seems to be working fine for me anyway - http://www.xtremesystems.org/forums/...&postcount=111
GA-X58A-UD7 Rev.2.0 first BIOS FA released. :D
and Manual.
Changes as UD5/UD3R Rev.2.0,BIOS is only for noted revision.
:D
GA-X58A-UD7(Rev.2.0) - FA
wath changes from rev.1 to rev.2 board???
New power delivery plan/design, and official ON/Off ports, I think those are the only two major changes
GA-X58A-UD7 Rev.2.0
http://img7.imageshack.us/img7/1613/34385142x.jpg
- CPU VRM Power design for extreme 6 core CPU OC
- Supports Intel Core i7-980X
- Supports 3 channel DDR3 up to 2200+
- Unique ON/OFF Charge
- 16 power phase design with manual back-up to each 8 phase
I do.
was one of the factors in buying this board.
one less thing to make/buy
i water cool so that ti have less moving parts in my machine. trying for no fans what so ever. but i don't think that will happen
keeps it quieter.
also my next step is to move my rad box into a different room, 2 small holes in the wall to run the water tubing.
silence is golden.
edit: just a pity the chipset block didn't have 1/2" barbs,
instead i split my flow to NB and video/ram.
I wouldnt exchange my rev1.0 for a new board, this board works awesome, I have 0 complaints with it. This and the P55A UD6 are the 2 best boards I have owned. :yepp:
Well 1 complaint, the pcie x1 slot is blocked and pretty much useless for my sound card, but thats the only thing.
