3. What the heck is the deal with the 20x multiplier then?
It is the DRAM multiplier and BCLK that people are combining with it that causes problems when combined with the QPI multiplier and the Uncore speed. Therefore, remembering our (safe) ratios of 8:9 Uncore to QPI we see that the QPI link speed must be a minimum of 3.6GHz or higher. In case of 20x200MHz the Uncore and QPI are exactly in this ratio and with the added stress on the core, cache, IMC, DRAM, etc. this becomes a problem. At this point clock oscillations become much more prominent and if the QPI link speed falls below the 9:8 ratio to Uncore at any point in time combined with the added stress on the components the system can and likely will become unstable. Hence, at 20x200MHz with a default memory, Uncore and QPI multipliers we cannot really have a 100% stable system.
Indeed, the highest reliable BCLK for default multipliers when using 20x core multiplier is 181MHz which with a 22x QPI multiplier would result in 3.982GHz QPI link. Even if you could set QPI multiplier to 20x, this would still not work for 99% of the boards out there as your QPI link would still be 4.0GHz. So what is the solution you ask? Memory multiplier. It needs to be lower. 1600MHz DRAM is approaching the maximum stress point for 20x200MHz core settings as it pushes on the limits of Uncore and QPI too much. By using a lower memory multiplier (say 6x if possible) the DRAM speed would become 6x200MHz or 1200MHz, Uncore could then be set at 2.4GHz with a lower multiplier which would then allow the QPI link to stay at 18x and well below the QPI link limits but still in a stable ratio to the Uncore.
Guess I need to lower my Ram Multi. This is my conclusion. And in turn, lowering it, couldn't I bump my speed past 220 easily?
