sure, the lowest multi.
I can get to 221 without adding any voltage. But no matter what i do 222 just won't post. It seems many board out there also have this limit.:shrug:
That's probably just the limit of the current X58 chipset. Revision B3 might fix that.
Hello, just mounted the R2E with latest BIOS (1306) and I noted that with my Xeon W3250 D0 cpu I can set the memory multipliers only up to 1:4 and I can choose only two values from BIOS.
i.e. if I set BCLK to 200 MHz, I can choose only 1333 and 1600 MHz as memory frequencies.
Anyone with R2E and a Xeon can confirm this behavior?
This LINK seems to confirm it :(
I don't have in my BIOS the two controls that are enlighten in yellow:
http://img148.imageshack.us/img148/1998/r2exeon.jpg
I can confirm this for you. I have already looked into it a few days ago. Xeon W3520 is fully locked chip. DRAM, Uncore, and QPI are all locked. You only have two options for DRAM, 6x and 8x. You know how they say, if it seems to good to be true (like this chip) it probably is...I knew there had to be a catch with it.
Just got around to benchmarking my latest rig and was very supprised at the poor results.
Even using the most basic bench of wPrime v1.55, 32M - 8.5+ sec and 1024 is 269.6+ seconds.
This seems very poor to me and when compared to the same CPU and memory of other systems on HWbot.com they are definatly poor.
I have tried almost everything I can think of to no avail.
Any help is truely appreiciated.
Code:System config
MB - Asus Rampage 2 Extreme V2
BIOS - 1306
CPU - i920
RAM - OCZ Blade Series 6GB (3 x 2GB) DDR3 2000 (PC3 16000)
CPU Cooler - VapoChill Lightspeed (Phase Cooler -45C +)
Liquid Cooling - Koolance Exos 2.5 (1000w)
VGA - Sapphire HD4870x2 watercooled
PSU - Thermaltake Toughpower 1200w
HDD - Intel X25-M SSD
AI overclock - manual
OC from CPU level up - auto
OC from Memory level up - auto
CPU Ratio setting - 21
CPU Turbo Power Limit - disable
CPU configuration
CPU Ratio Setting - 21
C1E Support - disable
Hardware prefetcher - enable
Adjacent Cache line prefetcher - enable
Intel Virtualization tech - disabled
CPU TM Function - disable
Execute Disabled bit - disabled
Intel HT Technology - disable
Active Processor Cores - all
A20M - disabled
Intel C-STATE tech - disabled
BCLK frequency - 200
PCIE frequency - 100
DRAM frequency - DDR3 1603MHz
UCLK frequency - 3208MHz
QPI frequency - auto
Dram timing control
1st iformation - Insert Timings Here in
6-6-6-14-A(5)-A(74)-A(10)-A(7)-A(16)-A(0)
2nd information - Insert Timings Here in 1N-A(55)-A(58)-A(61)
3rd information - Insert Timings Here in
A(8)-A(8)-A(16)-A(7)-A(7)-A(7)-A(7)-A(6)-A(4)-A(7)-A(7)-A(4)
EPU II phase control - full phase
Load-line calibration - enable
CPU differential amplitude - auto
Extreme OV - disabled
Cpu voltage - 1.40000
CPU PLL voltage - auto
QPI-Dram voltage - auto
IOH voltage - auto
IOH PCIE voltage - auto
ICH voltage- auto
ICH PCIE voltage - auto
DRAM Bus voltage - 1.65681
DRAM REF voltage - auto
Debug mode - string
Keyboard TeakIt comtrol - disabled
CPU spread spectrum - disabled
PCIE spectrum - disabled
CPU clock skew - auto
IOH clock skew - auto
The Bios 1306 well be OK at 100% for me.
OC i920 @ 4300 1.49V Rock stable OCCT 65° WC.
"MB - Asus Rampage 2 Extreme V2"
Is that a different mobo than the regular RIIE? Wonder what the V2 is all about...
Enabling HT did lower the scores, but they are still not inline with others.
Will have to go back and do some benchmarking to find the problem.
I am positive that SpeedStep and C1E have to disabled.
Now to test the other settings to see how they affect things.
Not sure if this has already been mentioned, but I found out some interesting quarks about the REII today.
If you set the DRAM Bus Voltage to Auto it will push the voltage way past 1.65v in a heartbeat. :eek:
Here is some readings from Everest:
Voltage Values:
CPU Core 1.52 V
CPU PLL 1.82 V
North Bridge Core 1.27 V
North Bridge +1.5 V 1.51 V
South Bridge Core 1.32 V
South Bridge +1.5 V 1.51 V
QPI 1.50 V
DIMM 1.79 V:shrug:
This is with the Core i7 920 @ 4.6 Gig (B-220 M-21)
Still can not get the WPrime 32 times below 6 sec, even pushing the system this hard.
I have no idea what could be causing this problem.
After beating my brains out trying to squeze better numbers out of my system. I decided to try a different HD that I had setup with Windows XP 64, Vista Ultimate 64 and Windows 7 (64 bit).
Without even pushing the system very hard Windows 7 and Vista get wPrime 32 results in the very low 6 seconds @ 4.2G.
ARGH bitten again by MS.:rofl:
Hello All,
I have just completed a new build: i7-965, 6gb Corsair Dominator GT 1866, BFG GTX 295 in Quad, Vista 64, Thermaltake Toughpower 1200 and the Asus R2E r2 board. One immediate problem I am having is that only 4gb are being reported in bios (1306, 1104, 1205) and windows. However, CPU-Z reports 6gb. Memory is fine, checked it six ways from Sunday. I have seen this issue on other forumns and have tried some of the suggestions to no avail. Is this an RMA issue, bios issue, driver issue, I do not know. Any suggestions would be appreciated...
Sorry if I'm jumping in on this thread or out o fline with the question...
