I wouldn't say raise it, but definitely take it off of auto and set the voltage to standard.
Thought I would post this as it is one of the finer OC's I have hit. I stopped testing for a couple weeks - was starting to go batty. Maybe my chip needed a little rest?
[IMG]http://www2.mediafire.com/imgbnc.php...c891208a6g.jpg[/IMG]
Here you go, as promised :) It kept on going, 2h+ and then I finally stopped it. Temps were unchanged. Oh and, the load, it is 99.9% on all cores, but since priority was set to normal when I loaded CPUZ and went to take the screenshot it dropped off for a split second to 99.4% or whatever you see in the screenshot.
With good cooling this chip could do 4.4GHz or even 4.6GHz with HT on. On air 4.3GHz (another 100MHz) would be the absolute max I think with HT on. Still, considering that my room temp is 23C and that the temp around the computer is probably closer to 28C-29C this is very good. Finally an i7 940 worthy of its designation :p:
My previous chip needed 1.46V to do 4GHz and temps were in mid to high 80s. Better cooling would allow me to drop the volts further as well for the same overclock. If I open the balcony door when Priming to drop the ambient to about 17C-18C I can drop the voltages for 4.2GHz to 1.38V.
What does everyone think about cooling this thing with the CoolIt Freezone Elite cooler? I do not want to go water because it is too much hassle for me, but I am thinking about FZE. Any opinions on it? What kind of temps can I expect?
Man o man o man... tried reading through all this, but after a dozen or two pages I had to skip to the end. Still don't know the answer to my main question though.. even though I'm sure it's in there somewhere...
I'm thinking if I'm going to make the change and go i7 I should go with the 965. It's double the price of the 940 but doesn't it open up a few more opportunities???
:shrug:
ok guys, need quick answer if possible =)
I have right now a 3839A i7 920 in my hand purchased last night.
I called back frys electronics and where I live they have one B left, its 3838B processor.
Should I return this one (unopened) for that A?
Well the B processor was actually 3836B so I got it! woot =) now waiting for mobo and RAM....
With a Corsair 1866 Kit will i need 1.55 QPi voltage or will i be able to stay within Intel safety guidelines?
Isn't there always the option of underclocking the RAM if you must?
I used a regular Freezone on my old Opty 165 rig and it worked great. The Elite is supposedly capable of 250W of heat dissipation but given the minuscule amount of coolant and possible overloading of the TEC's, I would be hesitant to use one until further reviews become available.
Tbh, my Exos-2 LX was easy as hell to set up and keeps my 920 at ~70C full load with HT enabled at 4.0Ghz. These chips run hot, as you well know, and I'm not complaining with those results. Admittedly, the Exos-2 LX is a bit more expensive because you have to mate it with a nice water block (in my case a Swiftech Apogee GTZ), but it does work admirably.
I was a bit hesitant to go H20 because of my noobishness in that regard but it's paid off in spades so far. I've gotten the impression that an extra $100 or so won't bother you so I would suggest a H20 configuration.
dejanh, I have always been told that an overclock can't really be considered stable unless you can run prime (small FFTs) for 12 hours+ Can you??
Also, just out of interest what speed are you running your RAM @ now for that 4.2GHz clock?
Just sitting here waiting for the courier to turn up with i7 940 before I can see if 4.2GHz HT enabled if possible.
With regards to temps... don't be too sure about getting 4.3-4.6GHz with better cooling... I have a quad rad & GTZ block on a dedicated loop. My temps never exceeded 72c on my i7 920, however, I could not get past 4.0GHz prime (small FFTs) stable. 4.0GHz or below with HT & Turbo enabled is solid as a rock for me. But I want more!
That is subjective. If you are only on the Computer 2-3 hours at a time and you can run prime for 4 hours with no errors, wouldn't that be considered stable for your needs?
Sure, there are people that fold, etc and need that 24/7 stability, but like I said, it is subjective. I don't waste my time running prime for more than 4 hours. This is after I run Intel Burn Test first.
I disagree...partially. The 965 is essential if you are going extreme cooling. Above 220 bclk it's a crap shoot with every 920 out there no matter how good it is and how skilled the clocker is. The unlocked multi is key to getting 5ghz+ for serious benching.
that doesn't take away from the fact that on air or water, the 920, 940 and 965 are pretty much equals.
Will 1333 DDR3 work to take the 920 in the 4ghz range? or do I have to have 1600 capable RAM to take it that high? I read somewhere that in order for bclk to go above 160ish it has to have 1600 RAM. Is this true or can I still take the bclk above 160 and just drop the multiplier on the RAM down to stay within 1333 range?
