InfinityG35, you have Q9650 or QX9650?
Post up your actual bios settings using this template.
Code:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ + 0.0 ]
CPU Frequency 4.45GHz...........................[ 494 x 9.0]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 494 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 800mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
(G) MCH Frequency Latch.........................[ 400 ]
System Memory Multipler.........................[ 2.00D ]
Memory Frequency 1066...........................[ 988 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD[3].........................................[ 3 ]
tWTR[3].........................................[ 3 ]
tWR[6]..........................................[ 6 ]
tRFC[54]........................................[ 54 ]
tRTP[3].........................................[ 3 ]
Command Rate (cmd)[0]...........................[ 2T ]
******Channel A Timing Settings******
Static tRead Value [ 8 ] ................[ 9 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Enabled ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ 1066 ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.15 ]...................[ 1.400 ]
CPU Termination [ 1.20 ]...................[ 1.300 ]
CPU PLL [ 1.50 ]...................[ 1.500 ]
CPU Reference [ 0.760 ]...................[ 0.848 ]
MCH Core [ 1.100 ]...................[ 1.320 ]
MCH Reference [ 0.760 ]...................[ 0.863 ]
MCH/DRAM Refernce [ 0.900 ]...................[ 1.050 ]
ICH I/O [ 1.500 ]...................[ 1.500 ]
ICH Core [ 1.100 ]...................[ 1.100 ]
DRAM Voltage [ 1.800 ]...................[ 2.100 ]
DRAM Termination [ 0.900 ]...................[ 1.050 ]
Channel A Ref [ 0.900 ]...................[ 1.050 ]
Channel B Ref [ 0.900 ]...................[ 1.050 ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
OK. Below are my settings for 4050 mhz. Q9650 L829A405 VID 1.25 with UD3P rev 1.0
- For 4140 I need VTT of 1.44 and VCore of 1.35. Everything else the same.Code:******Motherboard Intelligent Tweaker (M.I.T.)******
CPU Frequency 4.05GHz...........................[ 450 x 9.0]
CPU Host Frequency (Mhz)........................[ 450 ]
Performance Enhance.............................[ Turbo ] Standard doesnt help
(G) MCH Frequency Latch.........................[ AUTO ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 1080 ]
tRAS............................................[ 18 ]
tRRD[3].........................................[ AUTO ]
tWTR[3].........................................[ AUTO ]
tWR[6]..........................................[ AUTO ]
tRFC[54]........................................[ AUTO ]
tRTP[3].........................................[ AUTO ]
Static tRead Value [ 8 ] ................[ Auto ]
DDR Write Training..............................[ Auto]
Drive Strength Profile..........................[ Auto ]
DDR Write Training..............................[ Auto ]
CPU Vcore [ 1.25 ]...................[ 1.30 ]
CPU Termination [ 1.20 ]...................[ 1.380 ]
CPU Reference [ 0.760 ]...................[ AUTO ]
MCH Core [ 1.100 ]...................[ 1.300 ]
MCH Reference [ 0.760 ]...................[ AUTO ]
MCH/DRAM Refernce [ 0.900 ]...................[ AUTO ]
ICH I/O [ 1.500 ]...................[ AUTO ]
ICH Core [ 1.100 ]...................[ AUTO ]
DRAM Termination [ 0.900 ]...................[ AUTO ]
Channel A Ref [ 0.900 ]...................[ AUTO ]
Channel B Ref [ 0.900 ]...................[ AUTO ]
No-Execute memory Protect.......................[ Enabled ] Disabled doesnt help
Virtualization Technology.......................[ Enabled ] Disabled doesnt help
- Mem can go up to 1120 so 4200 should be a problem.
- Temps are 62C prime, and 70C Intelburntest
- MCH @ 1.40 doesnt help.
Try this out. Leaving the cpu and mch references to auto is probably the problem. I put in a little more vcore just to help make sure its not going to be an issue, you can lower it later or just raise the fsb if stable.
(G) MCH Frequency Latch.........................[ 333 ]
tRRD[3].........................................[ 3 ] these are stock for my ram so use if you want
Static tRead Value [ 8 ] ................[ 8 ]
CPU Vcore [ 1.15 ]...................[ 1.31250 ]
CPU Termination [ 1.20 ]...................[ 1.280 ]
CPU Reference [ 0.760 ]...................[ 0.835 ]
MCH Reference [ 0.760 ]...................[ 0.850 ]
Anybody had this, all i did was remve one of my HDD's, i tried unplugging the power for 1/2 hour, loaded defaults, booted fine at deefault, once i put my overclock back i get stuck at this screen.
http://i152.photobucket.com/albums/s...e/P1010393.jpg
That's weird. Looks like something got corrupted, did you try re-flashing the Bios?
Here's my Q9650 @ 450x9.....
http://i21.photobucket.com/albums/b2...oursprime4.jpg
I hope this is an appropriate place to post this, but where's a good place to pick up a relatively cheap q9650 these days? Anywhere cheaper than the egg?
anybody here have a rampage formula board? my pc won't load windows when i'm trying to set 4Ghz on the bios , care to share your settings?
Hey guys
finally my BFG GTX285 H20 OC arrived yesterday...so after some hours of surgery :D i shoot a 3DM06 in her stock clocks with the Q9650 at my stable 4500mhz
i was astonished how fast the combo is and how cool is the card max load temp is 40C at 24,5C ambient / 19C outside, its 15C less than the ultra, so my core readings lowered like 3C
http://img32.imageshack.us/img32/71/...stockxp321.jpg
very nice scores and OC andressergio:up:
amazingly low temps on the card
i wish i could have gotten my Q9650 to do 9x500@4500 ddr1200.i can do it with my E8400,but i would love to have done it with a Quad.
i bet it the system just screams
just grab a L828A446 and you will mate ;)
you can feel the speed took me a long time to get the system this fast and i love it, i was so anxious that i just cut the tubes and installed it, i was going to remove all plasticidez tygons but i couldn't lol, i just wanted to try this beast :D
Cheers radaja
Sergio
"just grab a L828A446 and you will mate"
easier said than done:rolleyes:
theres not many people willing to sell the good ones:(
a new one mate...you can find it on ebay we brought it from Canada all L828A446 are ALL vid 1,15to 1,1875 that's why i say so, of course such a low vid for me in summer i have to forget about 4400 or 4500 (i don like cores IDLE at 47C) but in winter its a pleasure :D
Sergio.
damn, 47 even on water, im guessing you dont have AC
Q9650@4,40ghz prime stable on water
http://www.abload.de/img/44ghzmqmc.jpg
i found out why my boot screen went all screwie, i installed a temp operating system using the gsata, then when i swapped it to the intel sata i got a screwed screen, swapped it back and now its fine, kinda strange.
Andrew
Nice overclock guys, I'm quite happy with mine at 4Ghz on air with a Zalman 9700NT cooler, does a pretty good job as well.
