Can't make OC stable at 3.6
I've manage to boot at 3.6, and the temps are good around 34ºC idle, but when i run prime95 I get errors, if i run prime's 1st option It works fine (Just CPU)
My System now is: Asus Rampage Extreme + Q9450 + Cellshock 14400 (1800Mhz) 8-7-6-21
Can anyone Please Assist?
My system Bios Looks Like this:
AI OVERCLOCK TUNER ==================== MANUAL
OC FROM CPU LEVEL ==================== AUTO
OC FROM MEMORY LEVEL UP ============== AUTO
FSB FREQUENCY ======================= 450
CPU RATIO SETTING ==================== 08
CPU CONFIGURATION:
CPU CLOCK SKEW ====================== AUTO
NB CLOCK SKEW ======================= AUTO
FSB STRAP TO NORTH BRIDGE ============= 400
PCIE FREQUENCY ====================== 100
DRAM FREQUENCY ===================== 1800
DRAM COMAND RATE =================== 2N
DRAM TIMING CONTROL ================= MANUAL
CAS LATENCY ======================== 8
RAS TO CAS DELAY ==================== 7
RAS PRE TIME ======================== 6
RAS ACT TIME ======================= 21
RAS TO RAS DELAY =================== Auto
REF CYCLE TIME ===================== 72
WRITE RECOVERY TIME ================ Auto
READ TO PRE TIME =================== Auto
READ TO WRITE DELAY S/D ============= Auto
WRITE TO READ DELAY S =============== Auto
WRITE TO READ DELAY D =============== Auto
READ TO READ DELAY S ================ Auto
READ TO READ DELAY D ================ Auto
WRITE TO WRITE DELAY S ============== Auto
WRITE TO WRITE DELAY D ============== Auto
WRITE TO PRE DELAY ================== Auto
READ TO PRE DELAY=================== Auto
PRE TO PRE DELAY==================== Auto
ALL PRE TO ACT DELAY================= Auto
ALL PRE TO REF DELAY================= Auto
DRAM STATIC READ CONTROL =========== DISABLED
DRAM DYNAMIC WRITE CONTROL ========= DISABLED
DRAM SKEW CONTROL ================= Auto
AI CLOCK TWISTER =================== Auto
AI TRANSACTION BOOSTER ============= STRONG
COMMON PERFORMANCE LEVEL ========== AUTO
PULL-IN OF CHA PH1 ================= DISABLED
PULL-IN OF CHA PH2 ================= DISABLED
PULL-IN OF CHB PH1 ================= DISABLED
PULL-IN OF CHB PH2 ================= DISABLED
EPU II PHASE CONTROL =============== AUTO
CPU VOLTAGE ====================== 1.40
LOAD-LINE CALIBRATION ============== ENABLED
CPU PLL VOLTAGEM ================== 1.55081
FSB TERMINATION VOLTAGEM ========== 1.40
CPU GTLVREF 0 ===================== +50
CPU GTLVRED 1 ===================== +50
CPU GTLVRED 2 ===================== +50
CPU GTLVRED 3 ===================== +50
NB GTLVRED ======================= +60
NORTH BRIDGE VOLTAGE ============== 1.55
DRAM VOLTAGEM ==================== 1.90
NB DDRVREF ======================== AUTO
DDR3 CHANNEL A VREF ================ AUTO
DDR3 CHANNEL B VREF ================ AUTO
SOUTH BRIDGE 1.5 VOLTAGE =========== 1.51106
SOUTH BRIDGE 1.05 VOLTAGE ========== 1.06039
CPU SPREAD SPRECTRUM ============== DISABLED
PCIE SPREAD SPECTRUM ============== DISABLED
ADVANCED CPU CONFIGUTION:
CPU RATION SETTING ================= 08
C1E SUPORT ======================== DISABLED
CPU TM FUNCTION =================== DISABLED
MAX CPUID VALUE LIMIT =============== DISABLED
VANDERPOOL TECHNOLOGY ============= ENABLED
EXECUTE DISABLED BIT ================ DISABLED
CORE MULTI- PRECESSING ============== ENABLED
