1 Attachment(s)
HDD Enable write caching on the disk
Might be related to some HDD slowness ?
I have enabled HDD in bios for AHCI fot the Intel chipset , also enabled ENHNCED
I have installed my winxp and used F6 to provide the InteL cipset driver (AHCI)
When Ii go to device Manager and ouble click on my HDD properties going into POLICIES TAB, i can see that both options are "greyed out" and there is a dot on the second one, while Enable Write caching on the disk doesnt have a chek mark.
Is this normal ? can this be a cause for HDD not performing to its best ability ?
also checking the Write cahce option once done makes it grey and you cant uncheck it.
did anyone have any experience with it and knows whether this behavior is normal, and what suppoed to be the best normal setting for it ?
4580 Audio Drivers -fooled us
Guys
I think we've been fooled.
there is no DTS in those drivers, I will expalin below.
I'll start form the end.
I think those drivers are exactly the same as teh 4530_32bit version that has no DTS (found on the ASUS website)
I told you guys i am not feelign its 100% perfect and i was right. this same feeling i had with the 4530 no DTS version when i tired it. it had small boot delay like now as comapred to the DTS version.
Now why do i thought we have DTS in this version,
Reason was that the soundmax pannel showed DTS TAB, but try to set things in it and u will see its reverts back to nothing, it doesnt keep the settings.
This is because there is no driver suport for this.
and now you ask so how come we have DTS TAB there with those Drivers ?
the ANSWER is simple, these are NOT stand alone drivers, they were supposed to be installed on TOP of the 4570 DTS version, this means the 4570 DTS version layed out the grounds for the sound max panel, but the 4580 just overun the core driver and left the leftovers unfunctional and not suported.
Basiclaly Asus wanted us to keep quite so they "made a so called advanced numebring onthe driver 4580" so we all be happy its "new" and basiclaly disabled DTS.
feels and looks like they wraped hte 4530_32bit version with a new numbering and overun the core 4570_DTS drivers.
a bunch of crap.
