starostise just seen your 3000 in your signature using 1.6v. What idle and loads temps did you get with it? Mines running 2.7GHz on 1.5v but not sure I'd like to put 1.6v through it... I get idle of 29.C and loads of 41.C at the moment.
Load temps blow 50 is ok . So if oyur temps wont pass 50 C under 1.6v ur safe.
Even little over 50 C wont hurt.
I got myself a venice 3000+
it is the one in this picture
http://img132.imageshack.us/img132/6034/dsc015311ir.jpg
I thought 0520fpaw was good, but it just won't do 1m @2,8ghz 1,65v?
aircooled
Any tips?
it was just max screen for 3024MHzQuote:
Originally Posted by matt1
idle @ nearly 35°C idle and 46-47 @ full
it was prime stable 2.7GHz on 1.32v air, 2.8 1.40v and 2.85 1.45v. but it's dead now :(
check here:
http://membres.lycos.fr/starostise/LBBLE0517DPMW/
3000 Venice
LBBLE 0516GPAW
320x9 2880MHz @ 1.55
VLDT 1.3
VDIMM 2.9
XP90-C/TT 92mm
SilenX 600W PSU
http://img101.imageshack.us/img101/1719/2880air8oa.jpg
How does this stack up?
Gah, looking at all the posts above i feel like i'm going to cry.
0518APMW - 255x10 @ 1.55V - load temps are around 40C, i'd go higher but i've got a crappy motherboard. :P
NBBWE 0608 GPMW
2820 @ 1.5v 35c - This is 24/7 level. Rock steady at this setting, primes all nite, but more importantly, plays oblivion at max settings 1600*1200 for 16 hours straight on the weekend. (this game is gonna eat my life) --- I don't have a screenie of this setting but I included one of 2800@1.46v (I upped the voltage to guarantee stability and added 2 mhz on the FSB just to get even numbers with the dividers - not sure if that makes any difference tho)
http://img183.imageshack.us/img183/7...t1461vv.th.jpg
3000 @ 1.7v - 32m prime stable, can't say if it could withstand anything else. There's no way I was gonna run this voltage for hours to test stability/load temps. Hitting 3.0 GHz was like an obsession to me. It ate me up inside until I could think of nothing else. Strangely though, once I hit that magic number I realized how meaningless it is and I will never run that high again with this chip.
http://img183.imageshack.us/img183/3...pi329qp.th.jpg
Overall Impression -- In a word, WOW. I prefer this chip over my old opty 165. My opty was not the best stepping. It would do 2.6GHz 24/7, but was quite hot and did not run oblivion as well as the venice. Many people rave about the quickness and multi-tasking of the dual-cores but for me, it's a non-issue. I have so many computers lying around that I have one setup for each task. I just moved so my network is completely down (except oblivion - that was priority :D) but my previous setup was one file server that holds my mp3s and movies, One HTPC for the stereo and TV, and one for intensive, time-consuming tasks (burning, decoding etc,) -- why bother with two cores when you can have 2 (or more) whole computers?
barmanmyk where did get that theme its cool
- MB : A8N-SLI Deluxe
- CPU : A64 3000+ @ 2600mhz (LBBLE 0545XPMW) @ 1.45v running at 32c idle and 34c stressed (Arctic cooling 64 pro)
- RAM : G.Skill ddr400 @ 238mhz 2.5-3-3-6
- GFX : 6600gt SLI setup
Ran 32m SuperPI last night, passed without any problems. Ran 3DMark 01/03 got 22000/16235 points.
3DMark 03 URL: http://service.futuremark.com/compare?2k3=4758786
CPUZ @ 2700mhz: http://valid.x86-secret.com/show_oc.php?id=89432
CPUZ @ 2600mhz: http://valid.x86-secret.com/show_oc.php?id=89547
Lowered the speed a bit for daily use so i won't have to use more VCore.
- Schmetterling
LBBLE 0520 (forgot packing code) 3200+
Doing 2550 @ stock voltage, dont know how this stacks up, and Im only using it for 1 day, but I thought I'd post some results, still working my way up to find it's limits, which seem to be high!
looks like my limit is ~2575 @ stok voltage, how are Venices doin these days?
Got another 3000+ today, stepping: LBBWE 0611DAG gonna do some testing tonight will keep you guys posted.
- Schmetterling
DAG? That must be a Chinese (assembly) one, only ever seen it with s754 Venices.Quote:
Originally Posted by Schmetterling
Indeed, it says 'assembled in China'. Will make a picture of my two cpu's before i mount my DAG.Quote:
Originally Posted by stone_cold_Jimi
- EDIT:
CPUZ Validation for 'LBBLE 0545XPMW'
CPUZ Validation for 'LBBWE 0611DAG'
CPUZ Validation for 'LBBWE 0611DAJ'
Just installed the DAG in my a8n-sli deluxe and booted to windows without any problems. Ran SuperPI 1.5 / XS and got 33.687/1m on 2600mhz (289 * 9). Will keep you guys posted.
Upped the HTT to 300mhz, running 300 * 9 now but it seems i need 1.55v to run on this ... ran SuperPI again and got 32.907 so it already improved a bit ... too bad that my G.Skill mem won't do more then 238mhz :( will have a look and see how far i can push this cpu today.
Seems that it will max out between 290/300mhz HTT, for some reason i don't think that the CPU's are causing this as the CPU's are totaly different but do about the same speed. I think my Asus a8n-sli is a piece of crap which is bugging me lol ... time to save some money and go for a DFI and some OCZ mem with TCCD or BH5 :)
- EDIT:
Both the CPU's run stable at 289 * 9 @ 1.45v (I use this so i can use the my ram as 333 so i runs at ~236mhz)
The TCaseMax for both:
'LBBLE 0545XPMW' = 57c
'LBBWE 0611DAG' = 53c
'LBBWE 0611DAJ' = 53c
- EDIT:
Got another one in my hands today (LBBWE 0611DAJ) for a customer of me but it's exactly the same as the DAG. As i promissed here's a picture of the DAG (The DAJ is the same just 1 letter changed)
http://img55.imageshack.us/img55/7963/0611dag8be.th.jpg
All three hit 2600mhz rock solid but until now only the 0545 is known to hit 2700 rock solid aswell. Pushed my memory up to 250mhz yesterday @ 3v with the 0545 running at 2745mhz and hit the 30.812s on SuperPI. Atm i'm waiting for my DFI Expert to come in so i can tweak the mem/cpu a bit more and hopefully hit the 17000 in 3dmark 03 with 2 6600gt's in SLI. (Got until 16867 now)
- Schmetterling
Anybody here reach 2.8-3.0+ Ghz for DH-E6?
Pls help me squeeze more juice out of my DH-E6 please...
Thanks a Alot, my comes with my Sig...
I'm waiting for my DFI mainboard, should arrive this week, then i will have a look and see how much i can get squeeze out of my 0545 (E3) and my 0611 (E6).Quote:
Originally Posted by adidassler
- EDIT:
Btw, you should be able to get you 1M SuperPI at a better time. I've got mine running at 30.8xx thats nearly one seconds faster then you.
- Schmetterling
Here are my results:
Athlon 64 3200+ Venice Socket 939
LBBLE E3
1.4v
Stock Cooling Fan from AMD, with a Tt Smart Case Fan II on the side of the case
Specs:
Biostar Tforce6100-939
OCZ EL 512MB/OCZ ELPE 512MB (Dual Channel)
Prime95 stable for 17+ hours
http://valid.x86-secret.com/show_oc?id=99516
http://img240.imageshack.us/img240/2...me951vj.th.jpg
http://img147.imageshack.us/my.php?image=prime18oy.jpg
here is mine !
mine is ada3500daa4bp
lbble 0520epmw
well i gues the damn link to picture is screwed , i will try to fix it and post it
but basicly mine is running stable with this settings
270x11=2970mhz with mem. 3-4-4-10 at 1:1
i tried in vain to go higher , will boot go to windows take screenie of cpz certification at 3008mhz but not stable either prime or super pi , i was super pi stable at 2999mhz but not prime so 2970 is the best i could get on air , i might try it soon on water to see if it goes higher but first i want to get my 2gig of ocz eb500 mem. then i might get wc !!
http://valid.x86-secret.com/show_oc?id=99533
why the hell can't i post pictures or links ? anyone ??!! help !!
But here's my Venice - 3000+ @ 2.835GHz. My load temps are normally are around 39C-ish on the Zalman. I've pretty much hit a wall with the chip though at that voltage - I'm not going any higher on air.
http://valid.x86-secret.com/show_oc?id=99672
For Super Pi times, I normally run in the late 31's on 1M. The RAM is really holding me back though; I am about to get some new stuff though (2GB for BF2 :D ) as the final upgrade for this machine.
http://img223.imageshack.us/my.php?i...perpi1m9yf.jpg
I love rockin' the Apple theme :D .
I have a 3000+ with the same stepping as this, which reached 2.5Ghz easily but I was being held back by something else.Quote:
Originally Posted by generalkido28
I also have a 3500+ LLBWE 0606GPMW, which I need to OC when I get some RAM that doesn't generate errors at SPD timings.
My rig:
http://img516.imageshack.us/img516/5855/case6oa.jpg
http://img507.imageshack.us/img507/7...einside2yq.jpg
http://img485.imageshack.us/img485/1...inside23my.jpg
http://img386.imageshack.us/img386/1...inside35pn.jpg
Inside:
ASUS A8N5X NF4 A3Rev2 s939 PCIe
Athlon64 s939 Venice Rev E6 2.0GHz 512kB L2
2x512MB DDR-400 CL2.5 4-4-8 CR2 2.5v Patriot
Creative Labs Audigy 2 6.1
Inno3D GeForce 6600 256MB DDR2 350/700 PCIe
2x160GB Maxtor SATA 7200RPM 8MB Cache
1x120GB Maxtor IDE 7200RPM 8MB Cache
LG DVD-ROM 16x
Sony CD-RW 40x
420W Deluxe ATX 120mm low noise
Cooler Master Vortex all cooper 90mm low noise
Overclocked:
HTT 1120MHz 4x280MHz
CPU 2.8GHz 10x280MHz 1.55v
DDR 466MHz 2.5-3-3-6 CR1 2.8v
GPU 525, VideoRAM 830
Cooling: air
OS: Windows XP Professional x64 edition
http://img504.imageshack.us/img504/6682/cpuz2rc.png
Benchmark results & scores:
Sandra 2005 Proffesional SR3:
- Arithmetic Dhrystone ALU: 13826 MIPS
- Arithmetic Whetstone iSSE3: 6039 MFLOPS
- Multimedia Integer x16 iSSE2: 20854 it/s
- Multimedia Float x8 iSSE2: 32124 it/s
- Memory bandwidth Int Buffered iSSE2: 6846MB/s
- Memory bandwidth Float Buffered iSSE2: 6798MB/s
http://img388.imageshack.us/img388/2...ndraram5jw.jpg
http://img485.imageshack.us/img485/660/sandramm6wq.jpg
http://img485.imageshack.us/img485/6...ndracpu6tl.jpg
Everest 2006 Ultimate:
http://img388.imageshack.us/img388/6...pudescript.png
CPU Photoworxx:
http://img388.imageshack.us/img388/4...puphotowor.png
CPU Queen:
http://img388.imageshack.us/img388/7...puqueen4pm.png
CPU ZLib:
http://img388.imageshack.us/img388/2...cpuzlib7bv.png
FPU Julia:
http://img388.imageshack.us/img388/8...pujulia1iu.png
FPU Mandel:
http://img388.imageshack.us/img388/1...pumandel8p.png
FPU Sinjulia:
http://img505.imageshack.us/img505/1...pusinjulia.png
Memory Latency:
http://img376.imageshack.us/img376/8...emlatency2.png
Memory Read:
http://img510.imageshack.us/img510/9...memread0ia.png
Memory Write:
http://img515.imageshack.us/img515/9...emwrite8wa.png
3D Mark 2005 Professional(1024x768 Trilinear filtering): 3655 3DMarks
http://img516.imageshack.us/img516/5221/3dmark6ei.jpg
SuperPi 1M: 30.813s
http://img525.imageshack.us/img525/8...i1mcpuz6bl.png
http://img518.imageshack.us/img518/4...i1mcpuz8lv.jpg
F.E.A.R. (640x480 pixel doubling, low quality):
- Minimum: 168 fps
- Average: 300 fps
- Maximum: 547 fps
http://img504.imageshack.us/img504/3...ettings5fi.jpg
got this out of my 3500+ Venice - just screenshot stable mind. Needs a lot more vcore.
http://img218.imageshack.us/img218/4118/untitled3ug.jpg
and this super pi run.
http://img218.imageshack.us/img218/2757/31250hw.jpg
hi there,
I am running my 3500+ venice at 2907MHz with 1.6v undervolted to 1.586 is this an okay voltage for Folding@home 24/7 or is it risky?
thanks a lot,
ben
any NBBWE 0619CAI ?
how does it OCbility?
thx
my NBBWE 0609 does 2.5GHz @ stock voltage, stock air cooling.Quote:
Originally Posted by kutujambak
@drozdov
thx for ur reply n info
any other with NBBWE 0619?
hi fellow overclockers...im a new member....so tell me what u think of my rig
ADA3000DAA4BW
NBBWE 0618FAB
X100347E60173
Cooling method:
Air with a tt beetle(proc)
Air with hr-05 (chipset)
Vcore:
1.68
mobo:
dfi ut lp expert
ram:
HyperX PC 3200AK2 (2-3-3-6-1T) (KHX 3200AK2) Winbond CH-5
gpu:
winfast px 7800 gt extreme
psu:
fortron epsilon series 600wt
hdd:
wd 80gb
http://img.villagephotos.com/p/2006-...3/Screen82.jpg
hey i got easy tune also. but i dont trust to use it. i try to stick with bios oc'ing.
A64 3200+ Venice
NBBWE 0609
TT Big Typhoon
2.7GHz @ 1.584v
sorry, but i cant provide a temp reading.. the result is from jannurary at a little lan party.. we opened the windows and set up an AC.. ambient temp was abuot 7 C* i think.. cpu load was between 24 and 28 C* as far as i remember :)
its a watercooled(waterchill, a bit modified) 3000+, 2 gb ram (~300MHz), 6600GT, DFI NF4 ultra-D
http://j-p-h.dk/venice.jpg
Venice 3200 NBBWE 0608 CPMW - Epox 9U1697 GLI
Venice 3200 NBBWE 0608 CPMW I bought 2xvenice the other was NBBWE 0608 GPMW which can do around 2700(both retail)
2800 is about the max the chip can do
Venice 3200 NBBWE 0608 CPMW - 2800 - 1.6v - 3xHTT - 2x512 corsair VS - 166 Divider - 30.906
http://img125.imageshack.us/img125/7...166dib7.th.png
This is what I run it at 247/rosetta stable, scythe ninja/2x1gb pqi/ and Epox 9U1697 GLI bought used from(I think roadie above) 350fsp/seagate 320 7200.10, threw it together for about £260 and dropped in my 79gt, used for gaming/net/and crunch. The epox 9u1697 is a bargain board, and compared to my outstanding epox 9npa+ does not suffer from vdroop, a bios update could do wonders for the 9u1697
http://img150.imageshack.us/img150/9...7glijw9.th.png
This was an OEM venice I had earlier this year, could not get it stable above 2500 in the neo 2 that I was usuing at the time
Venice 3200 - NBBWE 0608 GPMW - 2900 - OEM
http://img71.imageshack.us/img71/247...0oemeq6.th.png
wow look at this!
0617 TMPW : 3204MHZ Prime-stable! with normal water-cooling.
not mine... is the cpu of Ronny G. from germany
max cpuz screen was ~3400mhz@1.71V (i doesn't find the link atm)
a m8 of mine reached 2.95ghz on 3500+ E6 (did not say if its prime stable ;F)Quote:
my E6 3000+ on a crappy ASRock DS2 reched 8X325HTT @1.45V, and 9X300HTT @ 1.55V , waiting for another mobo change ;F or going for X2 3800+
Damn gianni-gt that 3200+ clocked nicely ;>
Please give more details including your memory timings,etc. Did your rig test Prime Stable and for how long did you stress test it?Quote:
Originally Posted by chunkylover77
3246mhz , air cooled, 1.65v. If anyone wants to go phase change test it they're welcome to.
http://valid.x86-secret.com/ccpuz.php?id=135428
stepping?Quote:
Originally Posted by ben rogers
Stepping is:
ADA3500DA4BW
CACAE 0611GPMW
WOW you got a great CPU mine wont do 2.8 with that voltageQuote:
________
F1/87
Currently the 3500+ is sitting in its box doing nothing as I upgraded it to a dual core....but that screenshot was just the max it can do on air cooling, no matter what - just to click the verify button on cpu-z made it reboot almost instantly.
It was stable at 2.907 GHz 24/7 folding@home, and benchmarking upto 3.05GHz for super pi...needs better cooling :D
the vcore was actually set to 1.7v in the BIOS, but it undervolts big time and speedfan was saying 1.64v IIRC.
mine need actual vcore @1.7 to prime stable @2.8 GHZ but temp never exceeds 48C
________
maryjane
same, but i can only get to 2.7 GHz and my temps get around 45c on a naked core.Quote:
Originally Posted by kemo6600
here's mine...
that's enough for me :)
http://img451.imageshack.us/img451/6150/ads305z9ha4.jpg
Hi,
just wondering what the program is you are using to monitor the voltages and temperatures?
thanks
Speed fan is compatible with lots of mobos try it out
btw: venice @ 1.92V still alive = WR
http://octs.ripping.org/dryicesessio..._with_info.jpg
^^ Wow, nice job. That's some chip.
the program is asus pcprobe 2Quote:
I have a 3,1 Ghz 3D-benchable Venice 3500+
It is also CACAE :)
exactly cacae0612apmw
http://service.futuremark.com/compare?3dm05=2479910
Originally Posted by Serge84
yes, and i'll try to get some pics up i been doin' some tweakin', and i got screen shots and saved the score ( the save option on the results screen ) cuz i have no internet, i'm at my sisters. i think i have the sse3 patch and xs 1.5 version. i want to see the real difference. i will run all pc mark and 3d mark, but dont have 3d mark 06 right now 2.71 ghz 1.589 v's according to cpu-z does not scale very well past that. i'll try to get a few hours of prime too and really pack this thread full of benches like it's supposed to be. managed 22.3k on 2k1 with my 6600gt @ 575/1147-8? mhz. get 64k in aquamark 64.7k i belive? seems my vid card only scores 8k in that and cpu scores 11k, so that means my vid-card is a bottle neck? how about a 7600gt? 600/1600 sounds pretty damn good lol and garunteed to do that just cuz i'll get the xfx one.
Originally Posted by gianni-gt
:eek: nc :eek:
WOW!!!! :woot:Quote:
Have you found other stable frequincies using a different Vcore?
It will help me much.....
Let me know....
3000+ Venice (LBBLE 0517 BPEW)
DFI LanParty SLI Expert
2x 512 MB Twinmos (no BH-5 or whatever, just budget):hm:
Tagan 550W
Zalman 9500 AM2 @ AS5
Ambient temp ~15C
Max air:
http://valid.x86-secret.com/cache/154314.png
Validation
vCore used was about 1.75V
SPi 1M stable:
http://www.amdgeeks.net/overclock/le...38312855540400
Validation
vCore used was about 1.71V, with higer FSB and lower MP it reboots.
Prime stable 10hrs:
http://www.amdgeeks.net/overclock/le...38318877254000
Validation
vCore used was 1.75V
My board seems to have a FSB wall, it won't go any higher than 365MHz, not even with a lower CPU-MP:mad:
Photo of the rig:
Click
I have an important question here regarding the dividers.
more ...
more still ....
coulda went longer with prime but i had a half day at work and wanted to play css lol
Actually my Venice is benchable @ 3.23 Ghz
http://service.futuremark.com/compare?2k1=9143805
and prime stable at 3 GhzQuote:
Originally Posted by Spacehead
http://spacehead.foppa.fi/3Ghzvakaa/3004MhzPrime16h.jpg
I benched with 3,1 Ghz with CPU-Z as proof:
http://spacehead.foppa.fi/3Ghzvakaa/...3DMark2001.jpg
