:clap:
Looks good, CAS 1.5 works...:)
:clap:
Remeber to update the first post with a link to the newest verrsion for convenience of new visitors :)Quote:
Originally Posted by lukija
Awsome work :toast:
New beta doesn't work in win2k3 32bit edition . I get a message "error loading driver" .
Regarding layout, I had to split CPU and DRAM pages since there was no place to put some addtional data.
Win2k3? Hmmm, I think it is a problem with some privileges. Run gpedit.msc in Run windows and find:
Computer configuration -> Windows settings -> Security settings -> Local Policies -> User Rights Assignment -> Load and unload device drivers. There should be Administrators. If you are not Admin, then add your user name. If that doesn't help, we will have to figure out something else.
Originally Posted by jrw
Of course, since this is not "final" release, I will keep it as attachment.
thanks but could you at least show memory speed/frequency on DRAM page as well so you can show the mem clocks with timings on one window :)Quote:
thanks
No , i'm admin .Quote:
Originally Posted by eva2000
Of course, i'm planing to do that anyway since you have a feeling that something is missing - memory speed and divider.
Back to the drawing board. :)Quote:
Originally Posted by Stelios
Computer configuration -> Windows settings -> Security settings -> Local Policies -> User Rights Assignment -> Load and unload device drivers -- does it say Administrators there?Quote:
Is your computer part of a network (I am asking because of security policies)?
If you can add temps,volts, and fan tools to the program it be awesome
Something like DFI smartgaurding on top of what you allready have :)
Hi.
Good work. The tool is great :toast:
but i've a question.
Because my CPU has got a coldbug i must start with 255x11. after boot into windows i upper the htt to 295x11 with clockgen. i works perfectly.
After that i start A64Info, but it still shows 255x11 :confused: Is this a Bug?
cpu-z shows the right speed (295x11):stick:
Thanks in Advance, Turrican
Yes, but it will take a lot of time to add support for various monitoring chips and stuff. Currently, I'm close to implement clock adjustment on nForce4 chipset. I hope it will be implemented in V0.6 final soon.
Good to hear :) Your tool is already awesome :woot:Quote:
c u Turrican
I guess it is. Try to restart A64Info. Or try other programs such as CrystalCPUID to confirm it. Which version are you using?Quote:
lukija you have make an excellent program my friend ;) ;) :clap: :clap:
keep up the good work!! ;) ;)
i tried both versions (V0.5 & V0.6). i also started the tool a few times, but no go.Quote:
CrystalCPUID shows the right htt
Very insteresting. I cannot reproduce it on my rig (Opteron 165 @ 2600MHz). I will reinvestigate clock measurement.
lukija, good job )
But, the new version doesn't load under Win2003 Ent Server...And the old one (0.5) shows completely incorrect values. Is it a big problem to solve?
thanks in advance
@ruis.av
I'm aware of that issue. New version cannot load driver under W2003. Old one too, so it gets random data. Since i don't have W2003 I'm asking you to read this post:
http://xtremesystems.org/forums/show...&postcount=160
If it doesn't help, it means that driver must be rewriten to support W2003.
@Turrican
Can you post a screenshot? That would help.
ok, here we go :)Quote:
This is a screen, before i set the htt to 295. as you can see all progs show the same :)
http://img80.imageshack.us/img80/8044/before8xz.th.jpg
and this is the screen, after i set it with clockgen to 295. i also restarted a64info, but it still shows 255;)
http://img84.imageshack.us/img84/8257/after6ga.th.jpg
c u Turrican
Turrican, please try this program:
http://avala.yubc.net/~lukija/clocktest.exe
To exit, just press any key. Try to change clock and watch what happens.
hmm. i always get this error, when i start the prog.
I downloaded it a few times but still no go. :(
http://img84.imageshack.us/img84/2089/error4ob.jpg
I try to translate it correct ;)
"The Program could not be started, because the application data (?) isn't correct. You should try to reinstall the Program."
c u Turrican
That's great news man :)Quote:
PS I get the same thing, it doesnt update the speed only shows the speed at bootup.
Works for me as well buddy, it refreshes like it should. Very nice program, thanks a lot!Quote:
- Schmetterling
