Originally Posted by iRoNeTiK
Yeah my card isn't the best overclocker..some people hit ~690 with 1.4, you should try 1.5 and if it dont work out just get rid of it (if you do the conductive pen mod). My previous card was a better oc`er but was one of the bad batch ones from eVGA.
Update. I had to knock my memory down to 900, 990 had massive artifacts in 3dmark03. I'm going to check voltage again today on the vmem and see how that is. Knocking the memory down to 900 only lowered my 05 score to 10481, so only 200 points, not bad.
Also when I was using powerstrip I would raise/lower my memory speed and hit apply and the screen would go blank for a second and then ask me if i wanted to keep these settings? Well anything above 947 it wouldnt do the blankscreen for a second. I would hit apply and then it just ask if i want to keep these settings? isnt that odd? So like 947 would do it but the next. 950+ wouldnt.
