Originally Posted by pancake
Add me to the vf900cu is crap brigade!
Just fitted mine to my x1800xt with some as5, idle temps are better around 8c down to 42c load temps are just as crap as before, peaked at 71c in a quick 3d06 run (2 minutes lol).
Think i will put the stock cooler back on as the heat coming off the vf900 i dont want inside my case to be honest, at least the stock cooler blows the air out the case!!
Right now its scanning for artifacts in ati tool , i havent disabled the 2d/3d profile thing so its only scanning at 2d clock speeds and voltages and is hovering at 68c!!
A quick question, it is probably me being stupid but... the vf 900 is a heatpipe cooler which works by having the pipes at the heatsink base with liquid in so the liquid is close to the core heats up travels as gas/vapor whatever you call it to the top of the heatsink/pipes were it cools down and travels back to the base as liquid.
My point is that the vf900 is upside down so wont the liquid be at the ends of the pipes in the first place and not by the core??
Or is there something i am missing?
