nice oc,with just 1.37v and air :toast:
:slap: Just wanted to let you know that the pics seem to be having trouble loading. Might I suggest www.imageshack.us or a similar hosting service...Quote:
Originally Posted by MFM
+1 I can't load em eitherQuote:
Originally Posted by isp
I want to try a 631/641 cpu.. From what I see it just have to clock good..!
Originally Posted by dpa
Cedarmills are mad chips and some guys are running 631 @ 5ghz+ on air and stable
WTF ! got any links to this ?Quote:
Originally Posted by PcCI2iminal
I know this is 65Nm thead, but for the record Here is Crystalmark 0.9.117Quote:
Originally Posted by boostedevo
http://img63.imageshack.us/img63/129...3ghz7fy.th.jpg
Cedarmill 631 @ 5.5ghzQuote:
Originally Posted by IluvIntel
http://www.xtremesystems.org/forums/...ad.php?t=87431
PRTeamJapan again my friend
and boostedevo got some great clocks with 6X1
You're not part of the PRTeamJapan?
Originally Posted by Shinuza
nope
:eek: A great clocker like you :confused:Quote:
They are loosing skill by not having you in their team :fact:
thx my friend
i can clock very well with air or water and sometimes waterchiller but i need serious cooling and stuff to play hard.
the PRTeamJapan are world class Ocers
just 2 weeks left to start my subzero adventure.
:slobber: Can't wait :banana:Quote:
Updated! Thx m8 :toast:Quote:
Does everyone in here lap their processor?? And is the vdroop mod necessary?
Vdroop mod is definately a must if you want sustained high O/C, regardless of vendor mobo with 4-phase cpu power supply. Not sure about other mobos with 8-phase. :)Quote:
Originally Posted by nicepun
well, with ambients of 0 degrees, I'm not suprised now but still very impressive. ;)Quote:
I think I do OK with 90nm on my 630 and ambients of 27 C.
My XE955 ES + Intel 975XBX ES from Intel:woot:
I think I need liquid cooling for o/cing this monster
3DMark06 Default CPU Score : 1885
http://www.xtremesystems.org/forums/...5&d=1138723266
http://www.xtremesystems.org/forums/...6&d=1138723266
you do very well :toast:
How do you OC with intel board? In BIOS or using software utility?Quote:
Originally Posted by kenofstephen
kenofstephen,
at what cpu speed you did these benches?
OK I looked at Intel website they seem to have an OC utility for the 975X. Anyone know the highest available FSB setting?
this time the 975XBX has overriding option on FSB, DRAM, Vcore and VdimmQuote:
Originally Posted by ar7786
it can overclock, though not as much as ASUS and Gigabyte
All run at defaults.:)Quote:
Originally Posted by Byron
Asus p5wd2-e northbridge danger den zchipset water cooled
intel 920d water cooled by storm g4
2 x 512mb patriot ddr2 700 fatbody d9 chips
ati x800gt02
this was stable but gradualy became unstable where pi would fail.
The p5wd2-e droops very badly.
bios vcore @ 1.45 when idle it showed 1.5 and under load 1.38 !
runing prime 95 at this speed failed when i started the 2nd core.
i am currently running 2 x prime 95 stable @ 300 x 14 4200 @ 1.412vcore
http://www.ljsnet.co.uk/p5wd2-e/920load.jpg
http://www.ljsnet.co.uk/p5wd2-e/9201mpi.jpg
http://www.ljsnet.co.uk/p5wd2-e/920ram1.jpg
http://www.ljsnet.co.uk/p5wd2-e/920ram2.jpg
