FYI this fix worked for all My BF2 connection/playing problems. I do not need winlaucher at all anymore.
good to hear dude.Quote:
Originally Posted by CODE 4
Great Guide tried on 2 different gaming rigs and both have no worries..Thank You.
Hey I am switching back to a single core opteron. Do i need to remove this? How do I do it properly? Thanks
pmed you.
Is there a fix for XP Pro x64 english version? I get The updatebr.inf file is invalid when I use the file you suggested.
From what i know, there is no fix for windows xp64......try emailing MS.Quote:
Originally Posted by iller
Thanks GAR for the update. :toast:
So how do the computer behave after the ms hotfix and AMD x2 driver.
Is it smooter?
I use AMD x2 driver, but dont know i i shoud install the ms hotfix.
I did...seems "smoother" Tho I didn't screw with the reg and still don't think ya should ;-)
What happens if you install the driver and/or hotfix etc in a different order?
Also how can you remove the hotfix if you wanted to install them from scratch?
If I swap CPU's frequently from single core to dual core should I install this hotfix? Will I need to un-install if I swap from dual core 170 to single core 146?
.... and what's the best way to backup the registry before doing this?
thanks!
TO remove the hotfix just follow these steps.
1 - uninstall the hotfix, go into ad/remove programs, click on show updates and remove update numbered KB896256
2 - reverse the registry entrie
3 - uninstall the drivers
4 - go into your boot.ini and remove /usepmtimer
Thanks GAR, my machine still freezes or restarts after installing all the fixes so I though I might remove them all aside from the AMD drivers and see how it goes. Then if it still freezes I'll install them in order.
I never dl'ed the hot fix or any of that crap and had a problem with cs which i found to be funny since cs:s runs smooth as butter, after about 2 hours of looking threw crap that wanted me to install stuff etc, (im not a fan of) i noticed when u go to task manager there is an affinity thing on the bottom, curious (went from 2.26 b4 and wasnt there, its a set the prog to what core, simply whenever u run it b4 u go into a game or anything uncheck one of the cores, game runs fast and fine now no patch or anything needed.
HOW TO FIX::::
CLT ALT DEL
go to HL.exe right click
SET AFFINITY
UNCHECK ONE OF THE CORES
all better
im poor from being a working adult with a mortage car payments etc however system is:
175 opteron 0530 core untouch for the moment
1 gig non dual channel 2.5 3 3 8 t2 ( 2 dual channel 512total, plus 512 1 stick :( )
crappy ass chaintech s1689 mother board 7/14 bios
9800 xt 8x 256mb oc'd 415c / 660m
300g diamond max maxtor 16mb sata 150
sound blaster audigy platium +
sony mdr-v900 headphones
xp pro
I contacted MS, and there is no hotfix for x64, but they promised to check if there was one on the way.
Note to WinXP SP1 users: None of this works with SP1. The hotfix and AMD's drivers won't install unless you have SP2.
This kinda sucks, cause I have some issues atm moment, and there's really no way for me to fix it. Right after a reboot, the system is perfectly fine. But after about 1 hour or so, things stutter. Even like animated gifs stutter. Anyone know a way to fix it for SP1 users? Only way to fix the stuttering atm is to set the affinity to 1 core, which is pretty annoying.
Hmmmm.....the only way to really fix it, is to upgrade to sp2.Quote:
Originally Posted by Silver Fox
espressx:
But then you lose the benefit of dual core gaming!! :stick: :stick:
GREAT FIND! My only question would be: why in the hell does it list 31 frickin cores!??! lol... a little excessive if you ask me!Quote:
Originally Posted by espressx
but again, I hadnt seen that yet, so ty!
setting the affinity to a certain core has been said before, this fix allows you to game without crashes, and you dont need to set affinity manually.Quote:
Originally Posted by palehorse
This fixed help me too... thankz....
Ok I installed the AMD Driver 1.2.2.1 drivers for Dual Core WinXP Pro 64Bit OS
I downloaded the MS Patch you provided (thank you) and when i go to install the patch it run all the way through then stops and gives me this error message: (Setup Error The updaterbr.inf file is invalid) What do i need to do to fix this ?????? Thanks I'll be online till then :)
After reading iller's post: I contacted MS, and there is no hotfix for x64, but they promised to check if there was one on the way. So i gues never mind (lol) Thanks anyways i'll wait
Any news on this? I planned on getting a DC too, but then it should be running the way it's supposed to.Quote:
I've been using x64 for like half a year now, and I really don't want to get back to x32.
by the time they decide to do that, MS VISTA will be out....i hope vista is a good OS.Quote:
Originally Posted by Radical_53
