If they're red heatspreaders, then they're 100% D9 fats. You'll probably be able to reattach the heatspreaders so long as you don't cut the clips off and you don't rip an IC off either. Use Steven's suggestion and look at the chips from the side under the spreader and you can tell by how wide they are if they're D9 fatty.Quote:
Originally Posted by SMa
