no cas 4 option. i havent checked each stick yet. i will drop temps to -20c or better with my chillbox in a few weeks. i am also planning a review for these sticks, but im waiting for my camera to come back from rma
Who buys a 754 board anymore? If I didn't have this x800xt I would upgrade to NF4, and X2. :stick:Quote:
Originally Posted by nn_step
Could it be the memroy controller on the 130nm Newcastle core?
definately but you can always go 939 very cheap these days...
I'm a little confused about people saying they got the Patriot sticks from newegg, I can't find them on newegg.. The only 1GB patriot sticks the egg has are different ones.
Outpost sells these:
PDC2G3200LLK $199.99 2-3-2-x
Newegg sells these:
PDC2G3200ELK $225.50 3-3-3-x
Which ones are you guys talking about?
Edit: I guess you guys bought the PEP1G3200LL single 1GB sticks?
"Edit: I guess you guys bought the PEP1G3200LL single 1GB sticks?"
Yup. :)
Yep...
yes
yes sir and if ge the green pcbs ima send a bomb threa to newegg..
I had to order mine on a holiday weekend now im not gonna get mine till end of next week I guess it hasnt even shipped out yet and its 830 pm on sat :(
I have a feeling that ima get shafted on these dimms because of lately the RAM gods have been takin mean dumps all over me with my bh-5 and now why would they have mercy on me with this set?
Sry for stating that it was tccd, aparently I didnt read enough to know what kind of ram it was Battlefield kinda drowned out all thoughts as to what kinds of ram it is, i just wanna play it decently and competetively, with 2 gigs..
its not tccd
and you just have to request the red on your RMA, worked first time with me...
Do they still have green pcbs? I have sent back the defective stick but didn't specify I want red back. Well I guess I can sent it back again if it was green. lol
By the way, I can't boot at 2-2-2-5 and 200. Did you guys try it?
trcd 2 is not going to happenQuote:
Originally Posted by zizo
2-2-2-5 1T doesn't stand a snowball's chance in hell with 1 Gb sticks...
hello every1 i am new to this forum. i have jus purchased 2 sticks of these patriot ram, RED pcb!! i managed to run 2-2-2-5 with no overclocking in dual channel mode, but wen i check with cpu-z it showed that i uses 5:4 divider, even thou i didn't tweak the ram (apart from the timing). i now currently run these sticks in an Intel platform... lg775 3ghz. is that normal that these ram's stock setting uses 5:4 divider? I put my other stick of Kingston 256mb value instead of the patriots and it shows 1:1 in cpu-z..
are there anything wrong with my patriot ram cos it runs a 5:4 divider at stock?
sorry i couldnt give much help cos i have limited understanding in tweaking memory, but i am happy with the patriots!! good memory.
In the near future i am looking to move to the amd platform.. but dont wanna get rid of my 6800le agp softmod to 6800GT. any suggestion of a new motherboard that can support agp graphics card? nforce4 chipset support agp? (sorry abit off topic)
how many mhz does it say the ram is running? 200mhz? or less?Quote:
Originally Posted by a_dragon_jai
it says frequency 160Mhz. FSB:Dram 5:4 in cpu-z with no overclock
thats why....look in your bios and see if you can set the ram 1:1 manually. it should be liek 1:1 or 200mhz...something like thatQuote:
I got 2-2-2-5 up to 185mhz :)
i really dont think its worth it though :(Quote:
The patriot sticks at the local australian store are apparently BE-6. How does that compare to BE-5/CE-6?
Thanks,
-Andrew
I cannot find the setting to change the ram ration in my bios. i don't think its the bios setting because it has always been on optimise setting, also i tried putting in my old stick of kingston 256mb stick it shows fsb ration in cpu-z as 1:1... so i am confused.Quote:
Originally Posted by stealth17
can you change it to aggressive or user control?Quote:
can you take some pics of your bios and i can help you?
hmm, so would this be a better buy than the OCZ plat. and the Mushkin Blues?
better buy, definatly...they are more expensive for basically the same thingQuote:
Originally Posted by kyp275
Not sure, would be interesting to find out though :p:Quote:
Originally Posted by AndrewK
