Configs look fine. As to the parental units, what is their issue? If it's the noise, then turning down the fans may help as long as it isn't the HSF. Conversely, you could just pull the Mobo out of the case and and use a tower HS with a 120mm fan for cooling-real quiet, works great. Then they might have a problem with the "eyesore" however... :p:
