Not verified yeT?
Not verified yeT?
I just loove this stuf.. nice one.. if only I had money for a newer cpu
http://valid.x86-secret.com/records....e293236e1ff200 :fact:
On CPU-Z records is still no.1 stilt's 6578MHz WTF :confused:
crazy clocks man
I'm speechless :slobber:
anyway 4-3-3 are high timmings.. IMO in 1:1 you guys should gain some ms
another Impressive thing is the mainboard,no mods ,no nothing..definitely the best 775 main around..
the P4@7.1ghz with only 1,6V :eek:
1:1 would be slow as hell with such "low" FSB even with 3-2-2-4 latencies.Quote:
Originally Posted by RoyaL
Memory bandwidth just wouldn´t be enough for SuperPI 8M test.
There isn´t that much difference between 3-2-2-4 and 3-3-3-4 in SuperPi.
It´s the CAS latency that makes the difference.
Say hello to my little friend ;)
http://www.akiba-pc.com/CR670.jpg
Let the games begin...
Congrats for this new WR, it is really impressive.
Do you think you could submit your record on the CPU-Z validator ? Would be really great :)
One more time congratulations.
I'm feelin a LN2 cooling :DQuote:
Originally Posted by The Stilt
This is gona be a very hot summer :D
Im in as well.
looking to pass with tripple stage
i need to get a 670 over here myself...
aarrrr i smell a great bench session from you guys :D succes
17s wouldnt be with a dothan 780 but a Prescott???????????????
surprized
P4 670 - Checked
Asus P5WD2 Prem. - Checked
Multiple Corsair DDR2 - Checked
Multiple LN2 containers - Checked
20L of LN2 - Checked
Moving towards to the runway and preparing to taxiing.
I love this 670 chip.
Previous 660 cpu did SuperPi 1M stable 4.55GHz with stock cooling and ~ 1.42V. This one dids 4.68GHz with stock cooling and 1.38V (1.25V set from bios ) :D
good luck for your 7GHz+Quote:
dont forget the extreme screenie
kyosen's 670 (i think)
http://210.163.215.170/c-board/c-boa...ne;no=3741;id=
【システムデータ】
M/B: ASUS P5WD2 PREMIUM, BIOS: 0422
CPU: Pentium4-670 SL7Z3 3507A661T
CPU Cooling: 液体窒素 by クリプロ3.1
Chipset Cooling: ノーマルシンクにファン送風
Memory: Corsair PC2-5400UL 512MB x2
VGA: RivaTNT2 32/PCI
HDD: IBM DTLA-307015
Power Supply: OCZ Power Stream 520
Vcore: 1.735V (実測), Vdimm: 2.30V (設定) , Vio: 3.601V (実測)
Vfsb: 1.50V (設定) , Vmch: 1.60V (設定) , Vich:1.20V (設定)
OS: Windows Server 2003 Enterprise
MEM: 4:5, 4-3-3-4-2-D-E
備考: ARCベンチ台Rev2.0改使用、室温約25℃
マザーはVcoreのみ改造
Performance mode: Turbo
PCI-Ex clock: Auto, PCI clock: 33.33MHz
nice.
what can these 670s run on water 24/7 ?
God damn, my 520W OCZ Powerstream just blew up :D
When I started SuperPI 1M calculation, I instantly saw a small flash inside the psu and some component flew out thru the grill of front fan...
Not a surprise that the psu is now completely dead.
It also "burned" (turned off) the 10A fuse of my lab room.
Pretty nice chip anyway. With 1.475V (from bios) I was able to run SuperPI 1M calculation thru at 6.46GHz. My previous 660 chip needed over 1.6V to do that.
Let´s hope that the psu didn´t take anything with it to the other side :D
Luckily I have some spare 600W Powerstreams in reserve ;)
I´m not pissed off because the psu, but the smell of burned silicon is pure horror :slapass:
By memesama
Clock(MHz)/FSB/FID : 7285.1(383.4x19.0)
CPU (Lot No.) : P4-670 (SL7Z3 / 3507A671T)
Cooling : ARC Pot Rev.12.1XE LN2
Vcore(V) : 1.834v(Actual)
M/B : ASUS P5WD2 Premium
Memory : CORSAIR PC2-5400UL 512MBx2
Vddr(V) : 2.4v(Actual)
Vio : 3.68V(Bios)
FSB/RAM Ratio : 4:5
DRAM Timing : 4-3-3-4-4 (bios)
OS : Server 2003
http://blue.ap.teacup.com/memesama39...1123941865.jpg
http://blue.ap.teacup.com/memesama39...1123942050.jpg
http://blue.ap.teacup.com/memesama39...1123942216.jpg
http://blue.ap.teacup.com/memesama3939/79.html
wow, amazinggggggggggggggg
only 7323MHz? :D
soon 17s!!
By memesama
Max CPUID, modPI 1M, 8M WR by memesama at his last trial before summer shutdwn in Japan.
Of course, he was sober and after Vmod this time.
Clock(MHz)/FSB/FID :7285.1MHz(383.4MHzx19.0)
CPU(Lot No.):P4-670 (SL7Z3 / 3507A671T)
Cooling:LN2 ARC Pot Rev.12.1XE
Vcore(V):1.834v(Actual)
M/B:ASUS P5WD2 Premium
Memory:CORSAIR PC2-5400UL 512MBx2
Vddr(V):2.4v(Actual)
Vio:3.68V(Bios)
FSB/RAM Ratio:4:5
DRAM Timing:4-3-3-4-4 (bios)
OS:Server 2003
modPI 1M: 18.093s
modPI 8M: 3m30.422s
Max CPUID
Comment:
17s was not so eazy-- will try again after vacation.
May be able to run modPI 8M @7200MHz
7.4G max CPUID may be possible :)
hey, there are 2 times the same post
+3523MHz = WR
Ooops, sorry for double posting :(
I could not see Enz0's posting while I was making my post.
