It does partially but not to the extent as it does on an Athlon64.Quote:
Originally Posted by The Stilt
The Big limiting factor on an Intel is the transfer Rate between the cpu and the Memory controller.
Cpu speed does make a small difference as the Faster the Cpu runs, the faster it gets it to the Cpu FSB.
But the BIG Factor in my scores is the OS. In win2003, There is a function Called "Lock Pages in Memory" which allows Sandra (or any program) To lock the same Memory pages for it's use Only as long as the program is open. This Makes a big difference.
I attached a Pic that shows Sandra's estimated Bandwidth efficiency.
