:D No, the board has been shipped today and will arrive Wednesday, I hope to get the waterblock also in time........ :toast:Quote:
My sticks of VX are going worse and worse... :brick: :brick: :brick:
Yesterday night they pass 720 loop of memtest #5, today they have some errors @260...
Maybe the memory controller of my winchester is going to burn??? :confused:
(sorry for my bad english...)
Do you think the Molex is important? You've been at this sort of thing longer than I have....Quote:
Originally Posted by xgman
I just tried 2.5 3 3 8. No go even at 3.1 volts. Lots of errors in Memtest. Then no post on return to previous settings :mad: But I fixed eventually, several CMOS clears + a battery removal later :)
So you haveing trouble with OCZ TCCD's??Quote:
I thought my TCCD problem might only be because I PDP mem with TCCD's..humm
Not at 2.5 3 4 7 - see post 143 ;)Quote:
Originally Posted by Blue078
hmm hopefully my new Gskill TCCD will play nice with this board
hy guys, im new here :toast:
I have veryy stupid driver/hardware problem.....
if I a program to start want and it double-click have I a delay of 1-2sek or I must around a program to start sometimes want 3-4 times on it to click
i installed usb 2.0 driver but not help ... :confused:
pleeease pleeeeeeeeeeeease help me :(
Is there anyway to update BIOS through windows with this motherboard? (don't have a floppy drive)
yep, winflashQuote:
Originally Posted by apu673
RTFM :)Quote:
for dual channel use Slot 2 and 4, (OR, but might be flakey) Slot 1 and 3
Slot 2 and 4 are the orange/reddish ones. (not yellow)
Put ONE dimm only in Slot 2
---> NO slots 1 and 2 and NOT slots 3 and 4
Please read the manual its in there and this is essential.
sry..just read that later after i replied :)Quote:
What do you guys use to flash the board to the new beta bios if it doesn't post because of the tccd memory issue? I'm suppose to get an Ultra-D this week and I have 2 X 512 OCZ 3200 plat. rev.2. Thanks.
Use winflash. Do a google search. First hit. Very easy and intuitive.Quote:
Originally Posted by coldcase
- Awperator
I'm using the Feb. 1 bios... it is the best... look here...
http://www.xtremesystems.org/forums/...ad.php?t=52557
Originally Posted by Awperator
Thanks but isn't Winflash a windows program? If you can't boot you need to flash before windows gets installed no?
It boots with one stick of memory just not two. Boot with one,flash,unplu,rest cmos, install 2nd.
Originally Posted by pudds
So you actually boot and need to install windows with one stick then flash, clear cmos and install the 2nd stick?
i got the thing to run ! sounds stupid , but my "anubis / typhoon" usb 2.0 hub was it ! just changed with "cytronix" 2.0 hub and no more problems, except when you turn on usb devices during power on machine it hangs, can live with this :DQuote:
just one problem left with VX/BH5 @ high voltages :rolleyes:
i love this board more & more :banana:
I posted this once to DFI-STREET.COM but Angry_Games replied like this.
So, I post it here too.Quote:
Originally Posted by Angry_Games
My friend CIMA did this amazing thing.
http://blog.livedoor.jp/cima/0dbd7629.png
M/B:LANPartyUT NF4 Ultra-D
BIOS:201
CPU:Athlon 64 3200+ CBBID 0441MPMW
CPU Cooling:XP-90
Memory:TwinMOS PC3200 BH-6 256MB x2
VGA?ATI XPERT 98 PCI 8MB
HDD?MAXTOR 6Y80P0
PowerSuplly?Zippy-460WS
Vcore:1.51V / Vdimm:3.80V / Vio:3.46V
OS:Windows Server 2003
But, when he sets Trtw to 1, it maxes out at memory clock of 250 or so whatever Vdimm is.
With other boards, like Epox EP-9NDA3+, we can reach higher memory clock with Trtw 1.
Like this (By my friend New Beetle).
http://cal930.sakura.ne.jp/cgi-bin/c...57S_DDR333.gif
Could someone ask Oskar what's going on?
hehe, i've got same RAM as you - I'm stuck at 290 (haven't tried 295 like you) it can't seem get it stable at 300HT, I tried OPB's settings, still no go, any setting suggestions? WE GOTTA MAKE THIS RAM >= 300! :DQuote:
I'll have a play later- at work at the mo ;)Quote:
Originally Posted by ominae
:( need helpQuote:
Originally Posted by ENGiN
Im having soooo many issues with CSS and SLI.... anyone else??
DFI Website down at moment,, butU can download the bios here...
http://www.ricco.karoo.net/down/
I'm a nube yeh,, got new hdd's and win xp pro,,
To flash the bios to the latest bios,, I just put the 2 bios files
(NF4LD201) & (AWDFLASH) on a floppy
start dos mode, and type "NF4LD201" to flash bios ? do i need 2 make floppy bootable some how ?
then shutdown, and install XP?
test sig
