Alrighty, just got my set of twinmos sp 3200 512MB and I have 1A4T (BH-5).
Seems good to me :)
Seems good to me :)
I ordered 2 sticks of speed premium 512mb PC3200 and one set of Twinmos PC3200 twin pack from Newegg last night, I will post results and what I recieved on Monday 5/16
wud you mind postin some 'best' results with 2.8 vdimm, my mobo max, before you throw the local power company's sub-station at'em..... :explode:Quote:
Originally Posted by Major Slaughter
with 2.8 you can't get 2-2-2-x timings, but you can get 2-3-2-x up to about 220 maybe 230 MHz.
Got 4 modules of PC3500 BH5 a few days ago, none will do stock timings at stock voltage/speed so they're going back. They're just about do stock at 2.8V but not a chance at 2.6
None will do over 250 2-2-2-5 at 3.5-3.7V in pairs. One will do it on its own but the others are pap.
sounds a bit like mine, cept mine wouldnt even do stock at 2.8 in dual channel and one of them in single channel.. they were sent back on tuesday, asked that instead of replacing with the 3500 bh5's if they could sent me the 3200 utt-ch5s in the hope they behave with my nf2 board alittle better.Quote:
Originally Posted by Minstadave
minstadave: Did you burn them in? Play with odd settings in on the DFI? I bought two sticks this week, and they do 260 2-2-2-5 at 3.5v, and they are 3200 SP BH-5 not 3500.
They haven't had any serious burn in, I've already had some PC3500 that was fine at stock, this latest lot though is awful, I'll burn in over night but if they won't do stock I don't have high hopes for them, they need atleast 2.77V to do stock :slap:Quote:
Originally Posted by Theo404
I've played with all the settings, drive strength of 7 seems most stable, tREF of 1168 or 3120 seem best. They just seem like bad modules, especially as my other PC3500s were fine.
Hi
I have just bought 2x512 Twinmos SP3200 CH-5. One of them wont even run stock no matter how much volt i give em. And the second one runs 245 2-2-2-5 @3.3v atm. More results to come when I get my faulty stick back from RMA in Germany :S
I Got the Twin pack today, they are CADT // Powerchip 0,11. The speed premium should be here Monday.
The healthy stick of mine burn in very quickly. It gave me like 80 errors in memtest (test 5) at 245Mhz 2-2-2-5 @3.3v. But already after burning them im at 2 hours no errors would occur at that speed anymore :banana:
I got one UTT and one BH-5 from newegg and they don't seem to like eachother. I'm currently running the BH-5 alone at 250@3.6 with 2-2-2-5, havnt tested with higher speeds or lower voltage yet.
I'll probably RMA the UTT, think I would be able to request a matching 1A4T or would I be better off RMA'ing both and hoping for 2 UTT's?
Hi... any idea what the 1A4B is?
I just now got around to testing the twinmos SP PC3200 I got from Newegg. They were both UTT BH-5. Right out of the box they did 250mhz @ 3.3v. I'm going to see if this whole "burn-in" stuff is for real. I've got them looping Memtest #5 at 270mhz 3.6v and I'm going to let them run for 3 or 4 days like that and then retest them if they survive ! lolQuote:
TMII400 from Newegg are all CADT.Quote:
I'm tired of this game and just ordered some Mushkin Redline XP4000 which I guess are much better although the price is very high.
i got a set of ch-5 aa4ts a few months ago that i run on the pc in my sig I recently ordered a nother gig of spp from the egg and just receiver the 1a4t which are bh-5 so i cane be more happy, crrently all i can do with my ch-5 are about 242 at 3.3 havent figured out how to mod it so i can run maybe 3.4 in it because the dam OCZ memory voltage thing (lol forgot the name) wont work for my DFI board :(
Having had my 3500SP bh-5 replaced ive just had 2x512 3200 SP (CH5/UTT) and so far these are destroying the other stuff i was sent (Mind you that seemed faulty)
on a nf7-s with 3.25 vdimm:
220 2-2-2-5 1T stable it originally seemed to go higher but heat was killing it dispite the 92mm fan attached the the ram
240 2-2-2-5 2T even more stable, i think with 2T timings i can probably go higher, not sure if its my board or the mem restricting me on the 1T/2T timings.
Hi. What can somebody say about AADT (Model NO: M2G9J19A-MK) with chips marked: M.tec 0404D TTD7608F8E50D with TwinMOS label. Can this stick work with timings 2-2-2-5 at nominal frequency 200MHz? In dual mode (MoBo: Soltek i865PE)?
AADT = Powerchip 0,13Quote:
Originally Posted by XaXoL
Crap memory, sorry. I would give it a try @ 200MHz 2-2-2-5 just in case...
My TwinMOS SP BH5 that I bought from newegg about 10 days ago could do memtest at 257fsb 1:1 on my DFI NF4 at 2-2-6-2 @ 3.5v (3.56vdimm checkpoint).
A couple months ago I had 3 sets of TwinMOS TMII 2x512 (50D) that did around high 240s to low 250s at 2-2-8-2. I also had two sets of 1x512 TwinMOS SP (AA4T 44D) where one could do like 255ish at 3.4v 2-2-8-2, and the other just couldn't do much at all.
I'm now trying to stabilize my new TwinMOS SP BH5 2x512, but I can't get it stable in windows at 250fsb, even though memtest could do much higher.
I'm thinking about buying more, since they are at $47 each now.
RafaDel What do You mean?Quote:
I'm saying if you are lucky you may run this memory at standard 200MHz with low timings. But be aware these are not Winbond chips so you kind of out of game.Quote:
i got Twinmos Twister DDR-533 rated with 266Mhz but CPUZ is reading it deffrent.. i can oc it to 280Mhz 1:1 max ,without any problems
i got 0ATT ? so whats that?
I just RMA my TWSP UTT (AA4T) and unfortunately I got back a (AADT) and this pair of RAM is suck. Once I install this pair into my slot....Beep......Beep.....So it's faulty. What on earth is this? I went to RMA and get a pair of faulty RAM back??? Anyway, I did some oc and the good stick can do stable at 230Mhz @ 2.5-3-3-8 only as compared to my previous AA4T which could do 260Mhz @ 2-2-2-2. Is there anyway I can push further my AADT or not?? Or I just RMA once more time????
My sig
Winnie3000+@2070@1.376vcore
DFI NF4 Ultra-D (REV.A3) Bios 618-3
TwinMos SP AADT 256mb x 1 @ 230mhz@2.5-3-3-8@2.9vdimm
IDE Hitachi 80gb 7200rpm 2 mb
Gigabyte 6600GT 570/1200
LG 16X DVD ROM
Gigabyte 52 X CDROM
Panasonic Floppy
icute 420 watt (20 pin)
I´d say theyre some Hynix Chip.Quote:
Originally Posted by SNIPoR
