odel: 3000+
Core: 0.09
Date: 0449
Stepping: CBBHD
Code: GPGW
Mhz: 2700mhz
Gain: 900Mhz
Vcore: 1.65v
FSBxMulti:300 x 9
Divider: 6:5(166) GSKILLpc4400 :(
Cooling: TT Bigwater
Stable: Prime95,Superpi,all 3dmark with few loops
odel: 3000+
Core: 0.09
Date: 0449
Stepping: CBBHD
Code: GPGW
Mhz: 2700mhz
Gain: 900Mhz
Vcore: 1.65v
FSBxMulti:300 x 9
Model: 3200
Core: 0.09
Date: 0451
Stepping: CBBID
Code: EPDW
Mhz: 2450
Gain: 450 :(
Vcore: 1.66
FBSx Multi: 10x245
Coolling: XP-90 & Panaflo
Stable: Prime95 over 15hrs, SuperPI 32M, 3Dmark, PCMark, etc.
10x250 same voltage, benchmark stable but not prime stable.
Model: 3000
Core: 0.09
Date: 0451
Stepping: CBBID
Code: MPM
Mhz: 2500
Gain: 700
Vcore: 1.71
FBSx Multi: 278x9
Divider : 166
Mobo : Neo2 Platinum Rev1
Coolling: XP-90 & TTsmartcasefan 90mm
Stable: SP2004 3hrs and up
2.89x9 benchable at 1.71vcore.
Model : 3500+
Core : Winchester
Stepping CBBID
Code : GPMW
MHz : 2650 (current with vcore. still trying to maxed it out)
Gain : 450
Vcore : 1,55v
FSB x Multi : 265 x 10
Divider : 133 (memory problems. memspeed not stable >191MHz :mad: )
Mobo : Gigabyte GA-K8NF-9, F1 Bios, nF4-4x
Cooling : Standard A64 from box.
Stable : superPI 1M.
http://img100.exs.cx/img100/9581/mya...vcore150iq.jpg
I'll try to update this when my memory problems are gone and have another cooling solution.
Model : 3000+
Core : Winchester
Stepping CBBID
Code : GPOW
MHz : 2502 mhz
Gain : 702 mhz
Vcore : 1.61-1.65v
FSB x Multi : 278x9
Divider : 166mhz due to bad cbbid memory controller (current memory able to run 570mhz ddr)
Mobo : MSI Neo2 Platinum w/ modded bios 1.41
Cooling : H2o
Stable : Yes super PI stable 10+ hours, css stable, 3dmark03/05 stable
http://img.photobucket.com/albums/v9...3rman/2502.jpg
Model: 3500+
Core: 130nm
Date: 0506
Stepping: CAA2C
Code: BPMW
Mhz: 2605
Gain: 4051.45V
FBSx Multi: 237*11
Divider : 200
Mobo : DFI nF4 Ultra-D
Coolling: Stock boxed cooler
Stable: SP2004 24hrs and up
http://koti.mbnet.fi/dani69/DFI%20nF....45V%2024H.gif
Model: 3500+
Core: 90nm
Date: 0502
Stepping: CBBID
Code: BPCW
Mhz: 2520 or 2600
Gain: 320 or 400
FSBxMulti: 280x9 or 260x10
Divider: 200
Mobo: DFI nF4 SLI-DR
Cooling: Stock HSF
Stable: Memtest86 v3.2 7 hrs+ 26 passes no error. 3Dmark03 and 05. Super
pi. Prime95 crap on me at those speeds. :mad:
Model: 3000+
Core: .09
Date: 0451
Stepping: CBBID
Code: FPMW
Mhz: 2610
Gain: 810 Mhz
Vcore: 1.69
FSBxMulti:290x9 (1:12, 2.5-3-3-6, 1T)
Cooling: Zalman CNPS-7000Cu
Stable: SuperTT 1M Stable
and another:
Model: 3000+
Core: .09
Date: 0451
Stepping: CBBID
Code: FPMW
Mhz: 2565
Gain: 765 Mhz
Vcore: 1.69
FSBxMulti:285x9 (1:12, 2.5-3-3-6, 1T)
Stable: SuperTT 1M Stable,32M Stable,Prime95-MemTest Stable...CPU Stability Test Run for 13 Hours 41 Minutes and Stable...
Model: 3000+
Core: 0.09
Date: 0444
Stepping: CBBHD
code: XPJW
Mhz: 2565
Gain: 765
Vcore: 1.62
FSBxMulti: 285x9 Ram 1:1
Cooling: Stock
Stable: Yes
can we formulate the table or the database or what ever the plan was?
Please have a look at the first post ;).Quote:
Originally Posted by bxa121
hehe, oops,
cheers m8!
Model: 3000+
Core: 0.09
Date: 0443
Stepping: CBBHD
code: MPM <--the Ms mean that it could be from any batch/week. :(
Mhz: 2547
Gain: 747
Vcore: 1.62
FSBxMulti: 283x9 1:1
Cooling: hyper6
Stable: prime95/snm
This is the absolute max of the cpu. Even a 10c load temp decrease did nothing.
no one has CBBGD stepping winnie?
Model: 3000+
Core: 0.09
Date: 0440
Stepping: CBBGD
Code: RPAW
Mhz: 2714
Gain: 914
Vcore: 1.5V
FSBxMulti: 301x9
Divider: 166
Cooling: air (stock hsf)
Stable: 3dmark01, 03, 05, superpi 1M, just test prime95 for 2 hours (hate to wait^_^)
on watercooling I got 2800 @1.58V, but haven`t test stability yet... I`ll do it later (still burning my sanmax bh-5 right now)
http://www.geocities.com/blitz3108/dfi30s.txt
Model: 3500+
Core: 0.13
Date: 05/06
Stepping: CAA2C
Code: BPMW
Mhz: 2400
Gain: 200
Vcore: 1.36
FSBxMulti: 240*10
Divider: 200
Cooling: Stock cooler - 80mm fan on Ram
Stable: 14 hours Dual Prime Stable
Link: My post on Overclockers Autralia You may need to sign-up to that forum to see it.
*This is not my max Overclock*
I am still using the stock cooler and it sucks. I was hitting 65C on stock voltage. And the heatsink was hot to touch aswell. So the thermal pad thing is working properly. I Need more money. :stick:
3000+ winchester
cbbid
xpaw
0510
2610 mhz @ 1,65 v
290*9
DFI ultra d
zalmann 7000 cu
Model: 3000+
Core: 0.09
Date: 0450
Stepping: CBBHD
Code: TPBW
Mhz: 2600
Gain: 800
Vcore: 1.55V
FSBxMulti: 290x9
Divider: 166
Cooling: air
Stable: Yes, BOINC, Prime95 and MS FS 2004 for 10 hours.
Link: Working on 290FSB with 200 divider, 2.6Ghz is my chips limit.
Concorde
Model: 3200+
Core: 0.09
Date: 0433
Stepping: CBBFD
Code: SPMW
Mhz: 2700
Gain: 700mhz
Vcore: 1.6v
FSBxMulti: 270x10
Divider: 200
Cooling: Vapochill LS
Stable: yes, can hit 2800 but not much over
Model: 3200+
Core: 0.09
Date: 0450
Stepping: CBBHD
Code: SPBW
Mhz: 2700
Gain: 700
Vcore: 1.48
FSBxMulti: 270*10
Divider: 200
Cooling: Thermalright XP90 & PAPST 90mm 1800rpm@1500rpm
Stable: 16 hours Prime Stable (2nd torture test and memtest86 free errors also)
Link: PRIME 16 hours
Another OC, same cpu
Model: 3200+
Core: 0.09
Date: 0450
Stepping: CBBHD
Code: SPBW
Mhz: 2600
Gain: 600
Vcore: 1.37 ;)
FSBxMulti: 260*10
Divider: 200
Stable: Prime Stable (2nd torture test and memtest86 free errors also)
Link: PRIME
Model: 3000+
Core: Winchester 0.09
Date: 05xx (i don't remember the month)
Stepping: CBBFD
Code: SPMW
Mhz: 2609
Gain: 809
Vcore: 1.47v REAL
FSBxMulti: 290x9 & 327*8
Divider: 133
Cooling: Water Cooled
Stable: yes, 4 hours of Prime, 32M SuperPI, i use it in daily :)
http://img117.echo.cx/img117/4498/290x97bx.th.jpg
Model: 3200+
Core: 0.09
Date: 0503
Stepping: CBBID
Code: i forget.. cbf taking off the xp-120 just for the code ;).
Mhz: 2620
Gain: 620
Vcore: 1.60
FSBxMulti: 262*10
Divider: "166"
Cooling: XP-120 w/ 120mm panaflo
Stable: 2 hours+ Prime Stable (still playing around for max overclock) these are my daily settings atm.
not too bad for a stubborn CBBID ;)
Model: 3000+
Core: 0.09
Date: 0448
Stepping: CBBHD
Code: SPAW
Mhz: 2800
Gain: 1000
Vcore: 1.52
FSBxMulti: 311*9
Divider: "166"
Cooling: Watercooling with tripple radi
Stable: 3 hours+ Prime Stable
Link: Prime
Model: 3200+
Core: 0.09
Date: 0448
Stepping: CBBHD
Code: SPAW
Mhz: 2700
Gain: 700
Vcore: 1.392
FSBxMulti: 270x10
Divider: "200"
Cooling: Air (7000B-Cu)
Stable: 100% Stable, prime95, pifast, game.
Link: http://img164.echo.cx/img164/1467/untitled0hb.jpg
Model: 3000+
Core: 0.09
Date: 0551
Stepping: LBBID
Code: ???
Mhz: 2602
Gain: 802
Vcore: 1.52
FSBxMulti: 289x9
Divider: "200"
Stable: Game
Link: http://img48.echo.cx/img48/4356/30009sy.jpg
Model: 3000+
Core: 0.09
Date: 0444
Stepping: CBBHD
Code: TPMW
Mhz: 2400
Gain: 600
Vcore: 1.200 V :)
FSBxMulti: 300 x 8
Divider: "133"
Cooling: Stock :( (for now)
Stable: Dual prime 95 1024k, superpi 32 M, games.
max 37 load, 30 idle.
I'm guessing it'll be 2.7-2.8 prime stable @ around 1.5 V with a decent cooling solution. I'll keep you posted.
EDIT: Oops, forgot the screenie :)
Model: 3000+
Core: 0.09
Date: 0511
Stepping: LBBID
Code: BPMW
Mhz: 2745
Gain: 945Mhz
Vcore: ~1,65V
FSBxMulti: (305x9)
Divider: (Please Give Divider Used 200,166,133, etc)
Cooling: (Air, Water, Phase, Dryice, Ln2)
Stable: Not stable at this clock speeds, but very "fancy" cooling for now( CM CK8-8JD2B-0L)
