some 6660GT SLI scores in my siggy. Will be moving on to 6800gt's in a day or so though.
LikwidKool, your scores have been updated to the list!
It will be interesting to see how the 6800 GT's stack up.
I added a little cushion on the 05 score:
12,153 http://service.futuremark.com/compare?3dm05=593372
well setup my DFI NF4 SLI-D with 217 bios with one of my new 3200+ 90nm 0445 VPMW cpus
2x eVGA 6800Ultra PCI-E @453/1215
DFI NF4 SLI-D 217 bios
2x 256MB KHX3200K2/512 BH-5 2-2-2-6
cpu:ram divider = 9/10
3dmark2003
3200+ @ 302HTT/271mhz mem = 2719mhz
= 23,921
3dmark05
3200+ @ 300HTT/270mhz mem = 2700mhz
= 10,976
3dmark2001
3200+ @ 271HTT/271mhz mem = 2710mhz
= 31,477
http://www.fileshosts.com/DFI/NF4_SL...5_23921_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...5_10976_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...5_31477_tn.jpg
11,4k with 6800gt sli 453/1215
fx53 270*10 @ 2,5-3-3-5-7-16-1T
msi diamond
http://service.futuremark.com/compare?3dm05=600676
maybe 2x6800 ultra -> 12k ? ;)
3dmark03 http://service.futuremark.com/compare?2k3=3720252
450/1200
fx53
msi diamond
Those are some nice clocks on the GT cards,//mar. And, a big improvement on the 05 score.
All scores updated!
correction i changed cpus from 3500+ @ 2.7ghz to 3200+ @ 2.7ghz :)
3 nice cpus i have
got 3500+ that does 2.755ghz
got 3200+ that does 2.717ghz
got 3200+ that does 2.700ghz
all at 1.6-1.63v
Yes, I always forget you have so many items. I did not even look at the CPU!Quote:
Originally Posted by eva2000
Nice results for air cooled GPU's and a watercooled FX-55!Quote:
Originally Posted by Skyline
AMD Athlon64 FX55 @ 200X14 , 2800Mhz
DFI LanParty UT SLI-D
GSkill TCCD 256MB X2 (2-2-2-5)
Galaxy GeForce 6800GT X2 , SLI (425/1190)
3DMark05 = 10783
iMAX, results posted. Moves you into the first spot on the 6600 SLI list!
Pesmerga, 05 result posted. We are almost at 11K just to get on the list! Nice work.
hehe i'm changing back to 3500+ on DFI NF4 and putting 3200+ in MSI K8N Neo2 for some air testing before i dust off my mach2 :DQuote:
Originally Posted by dwwalker14335
Phase cooling the CPU should open up your score quite a bit.Quote:
Let's see what the guy from down under can do in the middle of summer!
well i know 3500+ doesn't like sub zero temps but the 2x 3200+ might
Asus 6600GT TOP @574/1197 w/ stock cooling
MSI K8N Diamond
FX-55 @285x10
3D03: 16417
3D05: 7258
EDIT: Updated scores.
Thank 4 all :p: . Your work is great :toast:Quote:
i no have A64 300+ :D
I guess that would have been on killer overclock :eek:Quote:
Originally Posted by iMAX
You now have an A64 3000+.
Got my Sli rig up and running.
I wait for my G.Skill Memorys .
Athlon 64 3000+ @ 2700 GHz (9x300)
DFI LanParty NF4 SLI-DR
For Test 1 Gig A-Data PC4800 3-5-5-10 300@3,1V
My Memory at the moment Kingston HyperX KHX-3700
3-4-3-9 260@3,1V
2x Asus 6600GT SLI @570/1140
Tagan 480
3dMark 2003 15980
3d Mark 2005 6700
splmann, results posted.
Nice 03 run!
All scores updated!
And, it looks like H2Ogun moves into the no 1 XS spot for 6600 SLI!
Looks like #6 on the ORB for 05 and 03. Nice work!
Dave, will you be kind enough to update the list please? Post #167 above. I've just updated my score for 6600GT SLI. Thanks.
Looks like you caught me in the middle of my update! Score posted!Quote:
Originally Posted by H2OGun
Thanks Dave. Have to downgrade to 6600GT class series since 6800Us are gone. You have an amazing pair of 6800Us. They clock very well. I've tried like 8 6800Us and none can go beyond 470/1190.Quote:
I got lucky, I guess. I went through 4 cards and picked the two that were the closest match on core temp and memory auto detect. The similar core temps usually indicate similar reponse to overclocking and voltage tolerance. I actually picked the two middle cards. There was one card that idled at 41 C, two at 43C and one at 47C. They all pretty much auto detected to around 1180 on the memory with the stock HSF. Sometimes its all about luck ;)
