Thanks Ssilencer, after thinking about it i guess it's not that difficult but it would be good to be sure.
Is there any way to power a 12v fan on the value unit and then just use a fan controller.
How do you set the defaults on the start temp ect.is there any way it can be changed later if i had the correct equipment.
