YIKES! looks almost like a step backward. were you able to hit this htt clock before?
well it seems a bit more stable above 300HTT however, the 1T command is borked. The NIC still seems to need more work
Just received my VNF4 and SE6600 review samples I will finish up my current review work then this weekend I will start on the Chaintech reviews. Personally I am not to worried about onboard stuff never believed in its reliability and never used em so if I find the NIC flaking on me I'll just toss my 10/100 in there. My P4P800-D Onboard Sound and NIC are useless above 250Mhz too..
~Bob
Whos using the stock passive heatsink with this board and what are your temps like?
And is there any fan for cheap that will bolt right over the heatsink?
yeah, I have a 40 mm fan on mine. it's awesome. hook i up to a little zalman fan mate to control the whine. it is a very high rpm fan, but with a controller it's not bad at all/ definitely a must with this board. nf4 chipset is a bare core unlike nf3, if you look at it closely, it looks like a mobile chip.Quote:
Originally Posted by Ronin
cool.... how's it staying on? or is a zalman fan mate have provisions for stuff like this?
i just used a rubber band under the clips and through thte fan holes. you could use zip ties also. It's works great.Quote:
Originally Posted by texuspete00
I took my heatsink off, removed the original plaste, replaced it with AS5, remounted it, and added a cheap fan that was the same size as the heatsink (I picked it up from Fry's for $10.00). I just used long machine screws to mount it, and "pinched" a couple of the vanes on the heatsink a little closer together to let the screws grip better -- worked like a charm! The chipset stays cool to the touch even at the 300HT I run!Quote:
By the way, there is someone on Ebay selling a VNF4 Ultra that he damaged while working on the chipset heatsink. He tried to remove the chipset heatsink with the board still in the case (It did not work too well that way), and knocked the tops off of 2 of the transistors (the are both detached on one side). The auction is at (http://cgi.ebay.com/ws/eBayISAPI.dl...ssPageName=WDVW), and the board LOOKS reparable to me (with a little careful soldering). But then again, I HAVE my board, so I am not looking to get another that I may or may not be able to fix. Has anyone here ever tried to repair transistors which were knocked off like this? Is this an easy to do thing, or is it one of those (more work than it is worth) type of things?
its not easy to solder, but its easy to repair with liquid silver ;)
id say give it a try... but you never know if those kicked of transistors are the only damage the board took... but hey, its worth a try!
If the price stays this low (currently $1.25) until the end, I may buy it myself, and give it a try.Quote:
Originally Posted by saaya
By the way, i think your sig is a very nice gesture. So many use thiers for rants/bragging, etc, but yours is just a nice simple tribute to those hurt by the tsunami. Very cool.
Does anyone know if something happened to the Chaintech_Eng here who was posting in this thread? As I am reading back through the thread, it appears that all of his posts have been deleted (you can still see where people were responding to him tho)? It is very odd.
On a side note, a user on another forum (anandtech) is having a problem with his voltages on this board, and I was wondering if anyone here has experienced a similar problem. His post is quoted below:
Now I DO seem to remember that when I was messing around with my voltages, the first couple of bumps to the CPU voltage did not seem to take affect, and then once I got to a certain point, it did a big jump, so maybe I have the same issue? Has anyone else out there seen this with thier board? I would test it myself now, but I am not at home with my system for another couple of hours.Quote:
I've been experimenting with my motherboard and whether I set the voltages in the bios or with ClockGen I can't seem to get ANY voltages between 1.45 and 1.6 V (exclusive). So my only voltage options that my motherboard can physically reach are 1.4, 1.45, 1.6, 1.65 (1.7? I haven't tested). Also, my CPU temps are VERY low consistently producing idle temps of 17-20 degrees Celsius on idle and 27-33 degrees Celsius on full load (Prime95) even when o/ced to 2300 at 1.6V.
That is really strange, I'll send him an email.
Please do. I tried to, but in his profile, the ability to email him is disabled also! I am starting to wonder what is going on there...Quote:
Originally Posted by trans am
I have his chaintech email address ;)
I was the one that MajorPayne was quoting. The problem seems to span across all of the bios versions available. As far as I can tell, the problem seems to even transcend the bios itself! I hope someone at Chaintech gets word of this issue, since so far everyone that I've talked to and asked to see if they have this problem actually does have this problem. Anyone know how to contact Chaintech tech support directly? I'm surprised someone hasn't noticed this issue earlier.Quote:
Originally Posted by MajorPayne
I got a response from Chaintech_Eng (Jim)
Hey Alvin,
The reason why I left the forums and deleted the posts I made is that as an employee, I need to follow a strict policy for giving out releases and leaks of information. This is under the rule which needs to be approved first before providing these to the public and as well for protecting both the company and end/power users. .
However I may participate in the forums outside of the company under a different name to post comments and may offer some helpful tips and future developments.
As for the problem, we had already informed HQ about this so we are anxiously waiting for thier next bios release to this board.
Jimmy
Ok got my review sample running but NVMonitor won't run it says not compatible with this BIOS, so what else can I use?
I was able use MBM5 but since they stopped updating it well...
~Bob
speed fan?
I know the settings for this board in MBM if you need them, but it sounds like you already have it working. Let me know if you do tho.Quote:
Originally Posted by khellandros66
The newest beta bios fixes this and runs fine.Quote:
Ackbar, don't they have a new version of Ntune to download along with the new BIOS? I think you have to get them together, but I could be wrong, since I do not use Ntune anyway.Quote:
Originally Posted by Ackbar
Yup, on the link to the new bios, they included a link to the new ntune you need to download to use. Works great.Quote:
Well I finished setting up the Chaintech review sample, man I must uv gotten Lucky with my 3500+ NC so far its capable of running 290x9=2.61GHz on stock cooling and volts, though Prime95 locks up the computer after 2hrs.
I did have to Flash the BIOS as well my maxs was 220Mhz FSB on the dot.
Anyways I will have images and more in my review once it is done.
~Bob
New bios yesterday
http://www.chaintechusa.com/tw/eng/D...No=4&PISNo=318
I think I'll be trying it out after work. LMK if any of you have tried it :)
