hello all , i've find the way to reach high htt with this Motherboard , i can bench at more than 400 FSB , the defaults HTT timings are wrong.
Does anyone know who is able to mod them in bios ?
I'd Pmed tic-tac.
Modify them at each boot is really bad.
400 FSB Spi 32M OK with good HTT settings
Look at this database, i like it :)
If you want to share your results download OCCT.
http://www.ocbase.com/voirocctgraph_605.html
To have more than 320FSB rock try those settings with A64 tweaker 0.50 beta and use Clockgen.
Thx to codered again :toast:
6
5
4
2
2
5
2
misteroadster you tried new bios yet, any improvment over F1?
yes i can boot at 300FSB even higher :)
Has anyone had this board near 280 or 290 HTT with memory 1:1?
misterroadster, what are the voltage options on this board.
stock options is what i'm talking about, not terribly interested in voltmodding a 250$ board.
hmmm... you think that would be enough with a chilled water setup? -30C is what i'm hoping for res temps.
i got tccd, so that vddr is not a problem.
look at my new thread OC in Paris ;)
Is SATA locked or not, cause HERE people have problems.
Yea would also like to know that.
I can only say that Sata (Samsung 80GB Sata boot) worked fine for me at 300MHz HT (3x). I increased HT link voltage by 0.1V though.
I have another Asus board where Sata is not locked (K8V) and it would pack up at 225MHz maximum with that Samsung drive.
This leads me to believe that Sata on the K8NF-9 is locked.
Killeroy.
I'm on SATA-0, and it has to be locked.
Been clear over 300 1:1, Raptor 74GB is my boot drive / only drive.
It was very, very stable - that wouldn't happen with no lock. Likewise, PCI-E and PCI were locked right on the nose.
misteroadster,
Is that a custom or beta BIOS? I was secretly hoping you had hard-coded HTT or something. :p:
I just received all of my stuff. I am upgrading form a tbird and pci ati rage. I need alot of help in clocking this new equipment. Easytune locks up every time I try to start it up. I have what is in my sig and just got the rest today. AMD 3500winnie, XFX 6800ultra and the GA-K8NF-9.
