Chip number means nothing then, sence u can get 9 x 312 MHz ?
hey digger its me :stick: mine is a 0442 as i mentioned above :)Quote:
Originally Posted by GravediggA
Hei ;) U lucky guy! But i do not believe the "all after 0418 NBs are great" theorie! :)
it looks like newegg has them back in stock as well, so i'd assume they are the new revisions
What do u meen? that my 0408 isnt old?Quote:
Originally Posted by slayer899
Mine is 0420 A2 Korea. What a disaster, Psu switched on and the mobo+fans also turned on but no post :confused: WTF. Anybody got the same symptom? or how to fix. This is my 2nd. neo2(the other is fine).
Really?, well I got 2 Neo2 Platinum from August+newegg, one 0409A2 Taiwan and other 0410A2 Taiwan both has cool bot or False Start issueQuote:
Originally Posted by Dumo
I just got a new one, 0420 A2 Korea (from September)
Until now, no cold boot or false start bug. :)
S/N 0411blahblahblah
0440A2 Taiwan. Will be testing in a little while :slobber: :D
q41439,1 0409a2
s taiwan
k0409905190
Good or bad?Its Luck?
Same here, and i love the Board! :)
i just got and immediately hooked up my Neo2 Platinum / Winnie 3200+ Retail from www.monarchcomputer.com.
all fine and dandy as of now... unfortunately i need to wait couple more days for the OCZ Booster to arrive :(
installing win2003 server and other stuff.... i'll be playing with it and hopefully by the end of the weekend i will have some OCing fun... :)
S/N: K0411xxxxxx
http://www.xtremesystems.org/forums/...chmentid=20152
received the Neo today... gonna look up the revision tomorrow, 3am now.
btw, do the latest revisions come with an upgraded BIOS? my CPU aint here yet so I can't have a look
Im sure they do. If they dont them i am screwed up the but. But from what ive seen around the forums it should be fine.
I've got a board with the same k04099***etc serial at the moment, with another on its way (which should be the newer revision *fingers crossed*).Quote:
Originally Posted by M.Yazıcıoğlu
Anyone have any results for these series boards?
My new K8N Neo2 board just arrived from NewEgg, and the box S/N is:
K0410xxxxxx
The nF3 Ultra chip is:
0439A2
K KOREA
Originally Posted by bachus_anonym
i got the exact same revsion as you. 0440 A2 S TAIWAN ULTRA so far its only given me one problem and that was with my antec 550watt psu it would power up for like 2 seconds then shut off. for some reason i couldnt get my antec to work in this mb i wound up buying a new psu but the funny thing is the antec worked for the first three days without a hitch then i woke up one day and it wouldnt boot anymore?? strange? anyways let me know how yours oc's ill do the same...
thx perc,
Originally Posted by RebelsHaven
we have the same chipset,
NO ONE CAN guarantee it will OC well but have a taste from mine :)
http://xtremesystems.org/forums/show...&postcount=110
Perc, taht is a known bug with the msi. It seems to be a grounding issue with the system. Its only on the msi board with high end psus. It seems that only the really good psus have the grounding sense on it that immediatly turns it off when it realizes is not grounded correctly. You might want to try plugging your system into a power strip that you are SURE is properly grounded.
Im not sure if their is a fix for this at the moment.
got a new neo2 and have some strange readings from speedfan. the temp corresponding to the cpu socket, i get a temp of -44, i'm currently on air. anyone else with this problem?
@Gravedigga : , i see from ur sign , that u run at 255 ur bh-5 , have u tried higher?
I'm asking this , because i can prime at the same ram voltage and 254 (statistical error margin :) ) , and all timmings aggressive through tweaker , but anything above .. is unstable (even with massive ram voltage), , also i have a 0408A2 taiwan chipset.
For example i cant be stable (get BSOD's some times) at 260 even with 3.6 - 3.7 volt, and at 254 3.37v i primed for 6 hours today( i got bored and stopped it).I m almost sure that its not the memory, cause scaled perfectrly linear to this voltage.
At last i tried the vdd mod , but didnt give me any gains.. :( (tried 1.87 instead of 1.67).Any idea to stabilize at 260 and above? or its my winnie's memory controller that holds me back
hmmm? thats a good point. thing is i had the mb out of the case when this occured so maybe it was the plug and the power strip i was using? ill have to try using my antec once again and try using differnt ways of plugging it in. i wond up just buying a generic 500watt psu by "allied" my rails are decent and it doesnt seem to have all them sensitive sensors like the antec so it just works... anyways thx for the heads up it deff gives me somthing to try next time i get a chance..Quote:
Originally Posted by MaxxxRacer
thx perc,
Also have he 0408A2 chipset, primeing at 260x9 is no problem, but anything higher fails :D
http://people.freenet.de/funkflix/32k01.jpgQuote:
Originally Posted by papatsonis
Thats the settings i bench with, and no problems so far! Try the 1.36b bios! (3,65V)
U have 2 x 256MB or 2 x 512MB?
2x256 ., and i'll try again ,(one more time..) , thnx for the reply
btw . why use tras=1 ? i think the a64's IMC is using minimum 5 either way
Yeah, don't know that the IMC have a max. of 5, while i tested this settings! ;)
And it's saved with A64 Tweaker and start @ startup. Looks nice anyway! :D
