@Ubermann
Hey man want to have alittle contest?
Want to see who can get the most bandwidth out of stock speeds? (Being 200FSB)
If so feel free to copy and paste this as a template :p: :D
Since I am having trouble with OC I decided to start. I don't have anything to compare it to though...
Here is my results so far...
SiSoft Sandra Bandwidth: 3015MB/s
SiSoft Sandra Arithmetic: 9225 MIPS
SiSoft Sandra Multi-Media: 19,152 it/s
SuperPi: 44s
FSB BUS Frequency: 200
AGP BUS Frequency: 66
Clock Spred Spectrum:
LDT Downstream Width: AUTO
LDT Upstream Width: AUTO
LDT/FSB Frequency Ratio: AUTO
CPU/FSB Frequency Ratio: 10.0
CPU VID Control: 1.550V
CPU VID Special Control: AUTO
ChipSet Voltage Control: 1.6V
AGP Voltage Control: 1.5V
DRAM Voltage COntrol: 2.8V
DRAM Frequency Set (MHz): 200MHz 1:1
Command Per Clock (CPC): 1T
CAS Latency Control (TCL): 2
RAS# To CAS# Delay (TRCD): 2
Min RAS# Active Time (TRAS): 5
Row Precharge Time (TRP): 2
Row Cycle Time (TRC): AUTO
Row Refresh Cycle Time (TRFC): AUTO
Row To Row Delay (TRRD): AUTO
Write Recovery Time (TWR): AUTO
Write to Read Delay (TWTR): AUTO
Read To Write Delay (TWTR): AUTO
Refresh Period (TREF): AUTO
Write To CAS Latency (TWCL): AUTO
DQS Skew Control: AUTO
DQS Skew Value: AUTO
DRAM Drive Strength: AUTO
Max Async Latency: AUTO
Read Preamble Time: AUTO
Idle Cycle Limit: AUTO
Dynamic Counter: AUTO
R/W Queue Bypass: AUTO
Bypass Max: AUTO
32 Byte Granularity: AUTO
SiSoft Sandra Arithmetic: 9219 MIPS
SuperPi: 45s
Min RAS# Active Time (TRAS): 10
Bypass Max: AUTO
SiSoft Sandra Bandwidth: 3013MB/s
SiSoft Sandra Multi-Media: 19,149 it/s
SuperPi: 45s
DQS Skew Control: Increase
DQS Skew Value: 64
Bypass Max: AUTO
SiSoft Sandra Bandwidth: 3020MB/s
SuperPi: 45s
Max Async Latency: 08.0
Bypass Max: AUTO
SiSoft Sandra Bandwidth: 3017MB/s
SiSoft Sandra Multi-Media: 19,151 it/s
SuperPi: 44s
Write To CAS Latency (TWCL): 5
Bypass Max: AUTO
32 Byte Granularity: DISABLED
