This picture was taken 8 hours after the Cascade was turn off.Quote:
Originally posted by Evil_Spork
think you have enough insulation?
:slobber::slobber:
Notis the iceberg-formation. ;)
Edit: 2400@3300 change to 2400@33xx :p:
:slobber::slobber:
...................:slobber: :slobber: :slobber:
EIGHT HOURS ?!?!?
did you ever measure the temp, after the cascade was turn off eight hours ago ? :D ;)
come on! put your tong on it:eek:
do it, do it :stick:
btw. how do you get that big head, to fit in the sokket?
No socket.Quote:
insulation++!!!!!
how cold does that get?
Go a little back::Quote:
insulation++!!!!!
http://www.xtremesystems.org/forums/...762#post451762
Does that Head cool the Mosfets on the Mobo also?:)
indireckly, through the mobo.Quote:
insulation over mosfets...
:thumbsup: :worship: :worship: :worship:
Looks like a friggen cannon...lol. Probably look like a firefighter connecting to a fire hydrant when you put it on the mobo.
That's SOOOOOOOOOO darn extreme....just seems like it's time just to insulate/cover/air-proof the WHOLE board! Maybe build one of those air-tight boxes :D
C
Oh my good lord, every pic I see brings one more strand of drool down my chin. :slobber:
I just shake my head and chuckle when I read Tom's adventures .. incredble !
Tom, what is the highest you can bench 3dmark at with that thing ( assuming you can test with a cheap video card before the X800 / 6800 arrives ) >
As 3dmark2001 is reported cpu limited now on 3 tests out of 4 with the current high end cards then your "baby" should do a very very nice score. Good luck !
Regards
Andy
yeah right!
could u just bench 3dmark01 an 03 ? :)
only, to look, what kinda a*s your insane system would kick to space :D ;)
The last 2-3 dayes I have tested the mem, and fastest FSB/multi, some kombinations works very vell on SK8V others don't. It's not the same, as for my old FX-51. Some wall in the memspeed, when Sandra goes beon 7100 :rolleyes:
In a few dayes another FX53 comes, I want to se if it's better than the one I have:D
I can bench 3DMark03 with 3354 Mhz;)
3Dmark2001 might be 3361 or a little more.
Here you have a 3Dmark03 CPU testrun with very bad FSB and slow memtimings, just to se the max oc. Its already close to Oppainters WR.
http://service.futuremark.com/compare?2k3=2554657
I have done a few 3Dmark2001 car high run, they are 170++ with 9800xt default clocks. Lobby are nice to
:D :D
Here default 9800XT FX-53 set 3320 Mhz : 25350
http://service.futuremark.com/compare?2k1=7854130
I'll be back
:toast:
that last one seems to be invalid
ahh missed that. thnx!:p:Quote:
Originally posted by Tom Holck
Go a little back::
-120 with 350watt load is incredible!:eek:
Now it's works:p:Quote:
BtW is 25350 default 9800xt OK?
Naaw - You should score alittle bit more :slobber: ... ;)
OK Jacob, then bring me a decent Grafx: 6800U or x800Quote:
Then I'll puch 3370 Mhz ;)
Will do then m8 :toast:
You got Mail ;)
Ahh. found it.Quote:
It's a little better than 6800U default :D
Put me on that list to? - sounds like an easy way of getting a decent grafx :idea:Quote:
You got Mail ;)
:toast:
once again Tom, lookin' foreward to see you show of some danish 3dmark WRs :D
Damn! Tom, you just keep going. Anyway, could you share a bit of ya money with me?
Awesome bro!
