Originally posted by Formann
If the unit is tweaked for 240-250w of heatload, the evap may be flooded with coolant with only 130-150w heatload applied. If its too flooded the coolant wont have time to evaporate which again leeds to worse performance/higher temps.
Doing this sounds a little risky, cause unevaporated coolant might return to the compressor and shorten the lifetime of it.
Im far from an expert on the subject, but from what I have understood this is how it is. Right or wrong.. it sounds reasonable to me.
The coolant returning to the compressor, could that result in the seething I'm hearing? And the rise in evap temp?
